Download [Beta] QTS 4.0.1 Build0527 | ARM & x86 [Leak/Non-Official]
Silas Mariusz
rm -rf /
Help us, GOD!
10 213
31
2 317
153
39
forum.qnap.net.pl
Jakiś czas temu zgłaszałem firmie QNAP, problem w publicznym wydaniu QTS 4.0.0 odnośnie polskich fontów:
qts4-pic1_font_issue.png qts4-pic2_font_fixed_w_std.png qts4-pic3_font_fixed_custom.png
oraz z SSL'em...
Dziś udało mi się wyciągnąć poprawiony F/W z QNAP'a.
Wersja oprogramowanie to QTS 4.0.1, dzisiejszy build czyli 0527.
[POLISH] UWAGA!
Firmware NIE JEST oficjalnym wydaniem Beta oprogramowania QTS 4.0 do użytku publicznego. Należy instalować z ostrożnością.
[ENGLISH] WARNING!
Firmware images are LEAKED from QNAP and are not officially released for public view.
QNAP napisał:
FIRMWARE DISCLAIMER
DISCLAIMER OF WARRANTIES
THE BETA FIRMWARE ANNOUNCED BY QNAP IS PROVIDED ON A TRIAL BASIS ONLY AND WITHOUT WARRANTY OF ANY KIND. YOU ARE SUGGESTED NOT TO USE THE BETA FIRMWARE FOR ANY CRITICAL PURPOSE. BY DOWNLOADING THE BETA FIRMWARE IMAGES, YOU EXPRESSLY AGREE THAT THE USE OF THE FIRMWARE IS AT YOUR OWN RISK AND DISCRETION. YOU WILL BE SOLELY RESPONSIBLE FOR ANY DAMAGE TO YOUR NAS, COMPUTER SYSTEM, OR OTHER DEVICES OR ANY FORM OF DATA LOSS OR DAMAGE CAUSED BY DOWNLOADING OR USING THE FIRMWARE. QNAP DOES NOT GUARANTEE THERE IS NO ERROR OR BUG IN THE FIRMWARE, OR ANY KNOWN OR REPORTED ERRORS WILL BE CORRECTED.
QNAP EXPRESSLY DISCLAIMS ALL WARRANTIES OF ANY KIND, WHETHER EXPRESS OR IMPLIED, INCLUDING, BUT NOT LIMITED TO THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
LIMITATION OF LIABILITY
IN NO EVENT WILL QNAP BE LIABLE FOR ANY DAMAGE WHATSOEVER (INCLUDING WITHOUT LIMITATION DAMAGES RELATING TO LOST REVENUES OR PROFITS, LOST DATA, WORK STOPPAGE, COMPUTER FAILURE OR MALFUNCTION) RESULTING FROM OR IN ANY WAY RELATED TO THE USE OF THE BETA FIRMWARE , EVEN IF QNAP HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES AND REGARDLESS OF THE LEGAL THEORY ON WHICH SUCH DAMAGES ARE BASED.
Download links: RapidShare | Crocko | Zippyshare | Mediafire | Zshare | Netload
TS-110 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=1XLQC1MJLX
TS-112 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=1NRNFXEFZV
TS-119 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=1GG0WDQYE4
TS-120 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=7JKIKBEGQW
TS-509 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=5UBGZHIDAB
TS-121 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=5EVMOGKHII
TS-1269U QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=0QG5EFZIGR
TS-210 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=1LEEMWIQBR
TS-212 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=6CEIYXFIAR
TS-219 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=6RIYAHGHEG
TS-220 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=4XA0CSHSY5
TS-221 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=6EH0FXUJKE
TS-239 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=0IAVIBMZNO
TS-239PROII QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=1IAECICAKG
TS-259 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=3FVWZVZXJ3
TS-269 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=0NEDVIHZU3
TS-410 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=1IKUKCUWBD
TS-410U QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=4UQHJTDZDG
TS-412 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=7WSRMLJQAI
TS-412U QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=5ZQIEVEZIZ
TS-419P QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=3BHBAFFHIG
TS-419U QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=25MVBBEZKG
TS-420 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=7UFZEWGOHK
TS-421 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=8ENOKRYXUN
TS-421U QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=8TNYY3ARHV
TS-439 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=4QGSF2FHKL
TS-439 Pro II+ QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=7JADRBBIQR
TS-439 Pro II QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=3DBLMWQXIE
TS-439U QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=2YGIMKFTRG
TS-459 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=4YBCMRKRCL
TS-459U QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=5XGIMTEGAS
TS-469 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=2AETNFUXDZ
TS-469U QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=5HJHMHMQJR
TS-470 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=5JKWZDIYJB
TS-509 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=2IUQIBBKEB
TS-559 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=8UMIZFQDVG
TS-859 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=33WQCBFRNG
TS-869 QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=7BMLV2AYVX
TS-869U QTS 4.0.1 Build 0527: http://www.embedupload.com/?d=84N1I3EECJ
TS-219 QTS 4.0.1 Build 0524: http://www.embedupload.com/?d=1BUWDGEJYN
TS-410 QTS 4.0.1 Build 0524: http://www.embedupload.com/?d=0KMOY5GSMH
TS-419P QTS 4.0.1 Build 0524:http://www.embedupload.com/?d=5BARCECQKP
Enjoy!
Bardzo proszę o ten FW do TS-269L
Z góry dzięki
Reakcje: Silas Mariusz
Daj znać jak już zainstalujesz. Jedną z różnic na pewno jest to, że działa już spod przeglądarki IE10 a interfejs wydaje się działać szybciej.
Reakcje: pawurb1978
A 212 i 259 gdzie je?
Wielkie dzięki. Zapoznawszy się ze wszystkimi przestrogami puściłem instalkę. Była chwila grozy :) pierwsza próba utkneła na 6% i tak zostało. Na szczęście kolejna przeszła bez problemu. Na gorąco coś na plus i na minus. Faktycznie odnoszę wrażenie, że jest szybciej i na razie nie występuje losowe znikanie skrótów na pulpicie. Na minus, nie miełem jeszcze czasu tego rozgryźć ale w TV Station jest problem z EPG przez co większość kanałów wysiadła.
pawurb1978 i jak nowy FW? Jak dla mnie sam font poprawił już sporo :D
Ja osobiście (chyba jako jedyny - ponieważ nikt nie zgłaszał QNAP'owi tego problemu), mam problem z ustawieniem własnego tła oraz zdjęcia profilowego użytkownika. Problem występuje w 0510 i 0527, ale nie występował w 0416 :(
Jeśli możesz to sprawdź czy możesz ustawic qtsbg010.jpg z http://pool.qnapclub.pl/site/roaming/qnap/qts4/backgrounds/
Dzięki!
Jeszcze raz dzieki za FW. Przed instalką sprawdzałem z ciekawości te fonty i przyznaję że u siebie nic takiego nie widziałem. Podoba mi się że faktycznie interface działa wyraźnie szybciej. Pokusił bym się o stwierdzenie że nawet może o 50% szybciej. Akurat wczoraj zmieniałem tła tylko na własne, tak z ciekawości bo przy tej operacji znikały lub wariowały ikony na pulpitach i nie było z tym jakiegokolwiek problemu ani wcześniej ani teraz. Sprawdzę to co podałeś niestety dopiero wieczorem. Właśnie zostałem odcięty :( Jak pisałem wcześniej kożystam z TV Station. Po aktualizacji na większości kanałów przy próbie włączenia pojawia sie skanowanie EPG i wisi. Jak potrwa to chwilę dłużej to odcina dostęp do NASa. Wczoraj uznałem że to przypadek ale dziś jak chciałem z tym powalczyć stało się to samo więc nic na razie jestem odciety :)
Okay. Zaraz będe pisał w tej sprawie do QNAP'a... Dam znać co i jak.pawurb1978: Ustalmy sprawę. Wybierasz kanał, pojawia się skanowanie EPG, TV Station się zawiesza i po tej sytuacji tracisz zupełny dostęp do serwera NAS?
Reakcje: QNAP
Dokładnie tak. Pomaga restart niestety fizyczny. Nie zdązyłem niestety przeinstalować TV Station. Chciałem to zrobić teraz ale nie zdążyłem. Stwierdziłem że najpierw sprawdę jeszcze na innym kompie żeby nie okazało się że to wina np przeglądarki. Kożystam z tunera ASUSa U3100 mini. Dzieki.
Robie aktualizację na bierzaco więc powinno być 1.0.2 . Niestety na 100% teraz nie sprawdzę.
Wielkie dzieki :) Każda sugestia mile widziana.
pawurb1978 Mam dla Ciebie nie wiem czy złą czy dobrą wiadomość.
Dział QA firmy QNAP przeprowadził diagnostykę TV Station przy użyciu Twojego modelu serwera NAS - czyli TS-269L oraz na odbiorniku DVB-T, który również wymieniłeś - ASUS U3100 mini.
Nie udało się zreplikować ani potwierdzić najmniejszego problemu w działaniu TV Station.
Dodatkowo od czasu wydania poprzedniego buildu czyli 0510, TV Station nie uległo aktualizacji.
Ponieważ ciężko jest stwierdzić, czy wymienione przez Ciebie urządzenie występuje w kilku rewizjach i testowane przez dział jakości różni się od Twojego, sugerowane jest, abyś uruchomił serwer NAS, następnie wyłączył wszystkie usługi, odinstalował TV Station i wykonał restart urządzenia. Po ponownym uruchomieniu serwera przy wyłączonych wszystkich możliwych usługach, zainstalował i uruchomił TV Station.
Dzięki. Wykonałem powyższe, może w nieco innej kolejności :) to znaczy musiałem zrestartować żeby się do niego dostać a potem po prostu odinstalowałem i zainstalowałem na nowo TV Station i po konfiguracji zadziałało i jest ok. Zresztą jak pisałem wcześniej nie zdążyłem tego zrobić a miałem właśnie taki zamiar. Jeszcze raz dzięki i szkoda tylko że zawracałem głowę taka pierdołą.
Z pozytywów :) Pisałem poprzednio przy QTS 4.0.0, że na minus odnotowuję zwiększenie obciążenia procesora. Przy QTS 4.0.1 jestem mile zaskoczony. Utylizacja przy normalnej pracy nie przekracza 18 - 20%, gdzie przy ver. 3.8.2 utrzymywała się na poziomie 25% nie mówiąc o 4.0.0.
Sprawdziłem właśnie tą tapetę tła. Nie ma z tym żadnego problemu. W ramach ciekawostki - zniknęła mi jedna tapeta systemowa (szara tekstura). Po aktualizacji jeszcze była ale po którymś z kolei logowaniu nagle wyparowała. Nie ma jej też w folderze .../desktop/bg (o ile dobrze znalazłem stamtąd są pobierane).
Problem ze znikającymi ikonami jak widzę został definitywnie rozwiązany. Pozostałe usługi również wydają się działać poprawnie.
Myślę że wersja finalna już tuż tuż. :)
Ja osobiście (chyba jako jedyny - ponieważ nikt nie zgłaszał QNAP'owi tego problemu), mam problem z ustawieniem własnego tła oraz zdjęcia profilowego użytkownika. Problem występuje w 0510 i 0527, ale nie występował w 0416 :-(
Dzięki!
U mnie zmiana tapety chodzi bez problemu :>
Mam pytanie. Nie jest to nic specjalnie ważnego, pytam po prostu z ciekawości skoro testujemy nowy soft.
Pytanie a właściwie prośba o sprawdzenie zachowania się VideoStation u was. Powiedzmy że dostęp administracyjny mamy ustawiony na jakimś niestandardowym porcie np 1234. Jeśli zalogujemy sie i próbujemy otworzyć vidostation wywołanie wygląda mniej wiecej tak http://[adres]:1234/videostation/ i w tym momęcie strona nie otwiera się w całości, jest kompletnie rozwalona. Jeśli poprawimy adres na http://[adres]/videostation/ czyli na porcie 80 to otwiera się prawidłowo. Nie przeszkadza mi to ale jestem pewien, że w QTS 4.0.0 było ok. Próbowałem przeinstalować VideoStation ale bez efektu. Nie jest to też wina kompa lub przeglądarek - sprawdziłem. Ciekawi mnie czy to tylko u mnie coś nie tak czy po prostu taki mały błąd.
  1. utylizacja procesora
