2014-01-04,00:42:05,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-04,00:41:04,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-04,00:41:04,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Start examination.
2014-01-04,00:40:14,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-04,00:39:14,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-04,00:39:14,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Start examination.
2014-01-04,00:26:36,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-04,00:25:35,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-04,00:25:35,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Start examination.
2014-01-04,00:22:49,System started.
2014-01-04,00:15:46,System was shut down on Sat Jan 4 00:15:46 CET 2014.
2014-01-04,00:13:53,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-04,00:12:52,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-04,00:12:51,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Start examination.
2014-01-04,00:00:36,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-03,23:59:35,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-03,23:59:34,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Start examination.
2014-01-03,23:57:13,System started.
2014-01-03,23:55:09,System was shut down on Fri Jan 3 23:55:09 CET 2014.
2014-01-03,23:55:07,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] RAID device is inactive.
2014-01-03,23:55:07,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Hot-remove drive 4 failed.
2014-01-03,23:53:56,Drive 4 plugged out.
2014-01-03,23:51:07,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-03,23:50:05,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-03,23:50:04,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Start examination.
2014-01-03,23:43:35,System started.
2014-01-03,23:41:20,System was shut down on Fri Jan 3 23:41:20 CET 2014.
2014-01-03,23:35:52,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-03,23:34:50,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-03,23:34:48,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Start examination.
2014-01-03,23:31:39,[Drive 3] Bad Blocks Scan completed.
2014-01-03,23:31:01,[Drive 4] Bad Blocks Scan completed.
2014-01-03,23:29:37,[Drive 1] Bad Blocks Scan completed.
2014-01-03,23:27:46,[Drive 2] Bad Blocks Scan completed.
2014-01-03,22:50:52,[Drive 6] Bad Blocks Scan completed. 268 bad block(s) found.
2014-01-03,22:45:21,[Drive 5] Bad Blocks Scan completed. 209 bad block(s) found.
2014-01-03,22:30:14,[Drive 7] Bad Blocks Scan completed.
2014-01-03,17:50:19,[Drive 8] Bad Blocks Scan completed.
2014-01-03,15:16:57,[Drive 7] Start Scanning bad blocks.
2014-01-03,15:16:45,[Drive 6] Start Scanning bad blocks.
2014-01-03,15:16:34,[Drive 5] Start Scanning bad blocks.
2014-01-03,15:16:22,[Drive 4] Start Scanning bad blocks.
2014-01-03,15:16:05,[Drive 3] Start Scanning bad blocks.
2014-01-03,15:15:01,[Drive 2] Start Scanning bad blocks.
2014-01-03,15:14:41,[Drive 1] Start Scanning bad blocks.
2014-01-03,12:31:34,[Drive 8] Start Scanning bad blocks.
2014-01-03,12:28:28,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-03,12:27:27,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-03,12:27:25,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Start examination.
2014-01-03,12:23:13,System started.
2014-01-03,12:23:13,The system was not shut down properly last time.
2014-01-03,10:04:35,[Drive 8] Start Scanning bad blocks.
2014-01-03,10:02:30,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-03,10:01:30,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-03,10:01:30,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Start examination.
2014-01-03,09:32:50,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8]
2014-01-03,09:31:50,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Examination failed.
2014-01-03,09:31:50,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Start examination.
2014-01-03,09:15:47,System started.
2014-01-03,09:13:46,System was shut down on Fri Jan 3 09:13:46 CET 2014.
2014-01-03,04:07:04,System started.
2014-01-03,04:07:04,The system was not shut down properly last time.
2014-01-02,21:40:58,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Start rebuilding.
2014-01-02,21:40:56,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Rebuilding skipped.
2014-01-02,15:41:48,[RAID6 Disk Volume: Drive 1 2 3 4 5 6 7 Hot Spare Disk: 8] Start rebuilding.
