Download [RC2] QTS 4.2.0 Build 0910 | ARM & x86
Silas Mariusz
rm -rf /
Help us, GOD!
10 213
31
2 319
153
39
forum.qnap.net.pl
QTS4.2.0 Build 0910
[Bug Fixes]
- Fails to list files in File Station.
- Fixed potential CGI script vulnerabilities. Users are strongly urged to upgrade their NAS firmware with this release.
- Fixed Apache HTTP Server vulnerability.
- Fails to log into NAS after setting up 2-step verification.
- Fails to mount a USB device connected via a USB hub.
- After setting a bridge of a VPN Server to the default Gateway and connecting a VPN Client to the VPN Server, users will be unable to connect to the internet.
- Unnecessary attributes may be displayed after connecting to Google Drive/Microsoft OneDrive in File Station and right clicking on its folder.
- Videos will not be smoothly played when streaming via Airplay from the File Station toolbar.
- A cloned VM will be unable to boot up with Read/Write cache enabled if using a Block-based thin LUN.
- HGST HUS726020AL5210 (12Gbps SAS) drives may be missing when performing iometer tests for a certain period of time.
- The file base iSCSI LUN will be missing in the cloned volume of a snapshot clone.
- If a RAID 5 pool is expanded in Storage Management, the expanded HDD becomes a spare HDD.
- 250T/144T cannot be created on block-based thin LUNs.
- There are excessive samba processes after changing Windows ACL permissions and launching File Station.
- TS-269H models occasionally fail to copy files to Dropbox.
- When using Microsoft Edge, Surveillance Station will identify it as Internet Explorer.
- After upgrading to Surveillance Station 5.1.0.1, the default recordings folder in the playback path will be missing.
- Surveillance Station cannot display all the playback channels.
- Surveillance Station fails to generate event logs if changing SMTP server settings in Event Management.
- Fails to execute zip files when uploading them via FTP to the NAS when "Advanced Folder Permission" is enabled in File Station.
- Fails to apply new permissions for non-Administrator groups in File Station's permissions setup page.
- The owner and user list fields cannot display long usernames in File Station's permissions setup page.
- The Guest Access Rights in File Station's folder permissions always shows "-2" regardless of what value you give it.
[Note]
- QTS 4.2 is the final major firmware release for the following NAS models:
TS-410U, TS-412U, TS-410, TS-112, TS-212, TS-412, TS-110, TS-219, TS-210, TS-119, TS-419U, TS-419P, SS-439 Pro, SS-839 Pro, TS-239H, TS-239 Pro, TS-439 Pro, TS-439U-RP/ SP, TS-639 Pro, TS-509 Pro, TS-809 Pro, TS-809U-RP
[Download]
http://download.qnap.com/Storage/TS-210TurboNAS/TS-210_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-212TurboNAS/TS-212_20150910-4.2.0.zip
http://download.qnap.com/Storage/HS-210TurboNAS/HS-210_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-1269U-RP/TS-1269U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-509ProTurboNAS/TS-509_20150910-4.2.0.zip
http://download.qnap.com/Storage/SS-839ProTurboNAS/SS-839_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-410TurboNAS/TS-410_20150910-4.2.0.zip
http://download.qnap.com/Storage/TVS-X71/TVS-X71_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-239ProII+TurboNAS/TS-239PROII+_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-870ProTurboNAS/TS-870_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-670ProTurboNAS/TS-670_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-809U-RP/TS-809U_20150910-4.2.0.zip
http://download.qnap.com/Storage/IS-400/IS-400_20150910-4.2.0.zip
http://download.qnap.com/Storage/SS-469/SS-469_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-421TurboNAS/TS-421_20150910-4.2.0.zip
http://download.qnap.com/Storage/HS-251/HS-251_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-219TurboNAS/TS-219_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-121TurboNAS/TS-121_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-259ProTurboNAS/TS-259_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-559ProTurboNAS/TS-559_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-659ProTurboNAS/TS-659_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-470U-RP/TS-470U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-439ProTurboNAS/TS-439_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-X53S/TS-X53S_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-419UTurboNAS/TS-419U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-239ProTurboNAS/TS-239_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-X80/TS-X80_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-439ProII+TurboNAS/TS-439PROII+_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-859ProTurboNAS/TS-859_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-1679U-RP/TS-1679U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-421UTurboNAS/TS-421U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-412TurboNAS/TS-412_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-419PTurboNAS/TS-419P_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-470ProTurboNAS/TS-470_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-439UTurboNAS/TS-439U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-412UTurboNAS/TS-412U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-870U-RP/TS-870U_20150910-4.2.0.zip
http://download.qnap.com/Storage/SS-EC1279U-SAS-RP/SS-1279U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-239ProIITurboNAS/TS-239PROII_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-110TurboNAS/TS-110_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-669ProTurboNAS/TS-669_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-439ProIITurboNAS/TS-439PROII_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-879U-RPTurboNAS/TS-879U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-X31+/TS-X31+_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-469ProTurboNAS/TS-469_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-119TurboNAS/TS-119_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-X31/TS-X31_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-809ProTurboNAS/TS-809_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-X31U/TS-X31U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-420TurboNAS/TS-420_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-869ProTurboNAS/TS-869_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-1270U-RP/TS-1270U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-459ProTurboNAS/TS-459_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-220TurboNAS/TS-220_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-459UTurboNAS/TS-459U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-X51/TS-X51_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-120TurboNAS/TS-120_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-221TurboNAS/TS-221_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-869U-RP/TS-869U_20150910-4.2.0.zip
http://download.qnap.com/Storage/SS-439ProTurboNAS/SS-439_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-1279U-RP/TS-1279U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TVS-X71U/TVS-X71U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-112TurboNAS/TS-112_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-X80U/TS-X80U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TVS-X63/TVS-X63_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-639ProTurboNAS/TS-639_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-239HTurboNAS/TS-239H_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-X63U/TS-X63U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-269HTurboNAS/TS-269H_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-569ProTurboNAS/TS-569_20150910-4.2.0.zip
http://download.qnap.com/Storage/SS-EC1879U-SAS-RP/SS-1879U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-859U-RPTurboNAS/TS-859U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-469U-RP/TS-469U_20150910-4.2.0.zip
http://download.qnap.com/Storage/SS-EC2479U-SAS-RP/SS-2479U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-X51U/TS-X51U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-563/TS-563_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-420UTurboNAS/TS-420U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-879ProTurboNAS/TS-879_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-410UTurboNAS/TS-410U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-269ProTurboNAS/TS-269_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-1079ProTurboNAS/TS-1079_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-X53U/TS-X53U_20150910-4.2.0.zip
http://download.qnap.com/Storage/TS-X53/TS-X53_20150910-4.2.0.zip
witam
Po aktualizacji w FileStation nie mam dostępu do dysków, są widoczne na liście ale nie można do nich się dostać. Przez sambe, ftp i MC bez problemu
Jakiś pomysł ?
tez mam ten problem..próbowałem logowac sie z roznych laptopow, z roznych przegladarek...zawsze ten sam efekt... nie pokazuje mi katalogów na wolumenie...nie wiem czy jest na to jakis sposob czy trzeba na nowo stawiać QTS
Chodzi tylko browsowanie na aplikacji mobilnej (android). Na przeglądarkach echo.
Może teraz zaktualizują paczkę File Station. Jestem nowy. Można na jakiejś oficjalnej stronie zgłaszać takie bugi? Na S w programie beta była możliwość zgłaszania uwag bezpośrednio z pulpitu, tutaj tego nie widziałem.
Mnie z kolei po aktualizacji nie działa kamera IP (EPCAM) wyświetla mi się komunikat o nieprawidłowym porcie RTSP... Wcześniej wszystko działało.. szkoda
Mam to samo :(
jak sadzicie czy postawienie na nowo qts rozwiąże problem ? bo nie chce mi się na nowo tego robić...
Ja bym nie stawiał. Prędzej bym wygrał poprzednią wersję. Chociaż nie wiem jeszcze jak to jest z downgradem firmwaru w Qnapie. Na S nie było to takie proste.
Ja generalnie poczekam na rozwój wydarzeń
BTW w release info podali
Bug fixes "Fails to list files in File Station." - więc chyba im to nie wyszło.
W imieniu szefa działu programistów w firmię QNAP proszę o zdalny dostęp do File Station, aby mógł on sam osobiście zdiagnozować ten przypadek. Konto admina mile widziane.
Jetem zwarty i gotowy. Masz moje IP - bo wczoraj je zablokowałeś. Poświadczenia wyślę ci na PW.
Proste .. ja siedzie od ostatniej bety 2 na Stabilnym 4.1.4 z 20/08/15 .. fakt ze polowa rzeczy nei dziala - trzeba usunac i zainstalowac dla QTS 4.1.4 a nie dla 4.2.
Poza tym no problem. Czekam na stabilna 4.2.0 ... gdyz miewam pewne UPS problemy przy betach ... wiec testuje teraz ostatnia stabilna.
Nie widać folderów/plików w Filestation zgłoszone. W wersji 0901 i 0910 nie naprawili. A dzisiaj dostałem odpowiedź
Hello,
this is a known issue with recent versions and our developers are already working on a fix. I will keep you updated once I hear back from them.
Best regards,
Lukas Zemina
Mi przestało działać połączenie RTRR do ftp , pokazuje mi że jest zły użytkownik lub hasło (na 4.1.4 działało i filezilla łączę się bez problemu)
Zrywanie połączenia z dyskami zewnętrznymi przy wykonywaniu kopii. Czy można to nazwać krytyczne ??
Postaram się dziś sprawdzić ten problem. Jeśli u mnie również wystąpi natychmiast zgłoszę. Z Twojej strony przydały by się jakieś logi.
Możesz opisać w punktach jak przeprowadzić test?
