Download ImageMagick w serwerze Web
Not open for further replies.
Silas Mariusz
rm -rf /
Help us, GOD!
Apr 5, 2008
10,102
40
4,497
153
41
forum.qnap.net.pl
Nieaktualne! Imagemagick domyślnie wbudowany w obecną wersje PHP serwera QNAP NAS.
(Notka: Wymagany zainstalowany Optware/IPKG)
  1. Z centrum aplikacji zainstaluj Optware.
  2. Za pomocą klienta SSH (np. PuTTY) zaloguj się na serwer i wykonaj poniższe polecenia aby pobrać automatyczny skrypt instalujący ImageMagick:
    cd /share/Public
    wget http://pool.qnapclub.pl/site/tools/utils/ImageMagick.sh
    chmod +x ImageMagick.sh
    ./ImageMagick.sh install
    rm ImageMagick.sh
    /etc/init.d/ImageMagick.sh start
  3. Enjoy!
FYI: kod źródłowy skryptu:
#!/bin/sh
##   PHP ImageMagick and imagick extension auto-compiler tool
##   designed for QNAP TurboNAS, QTS4 compilant
##   Copyright © 2013, Silas Mariusz <silas@qnap.com.antispam>
##                     QNAP Club Polska
##   This program is free software; you can redistribute it and/or modify
##   it under the terms of the GNU General Public License as published by
##   the Free Software Foundation; either version 2, or (at your option)
##   any later version.
##   This program is distributed in the hope that it will be useful,
##   but WITHOUT ANY WARRANTY; without even the implied warranty of
##   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
##   GNU General Public License for more details.
##   You should have received a copy of the GNU General Public License
##   along with this program; if not, write to the Free Software Foundation,
##   Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
##   The latest version of this software can be obtained here:
##   https://forum.qnap.net.pl/
##   FILE: qlogWatcher.sh
##   RELEASE: 1.0
##   DATE: 2013-08-11
##   (dependencies: Optware)
NAME=imagick-module
QNAME=ImageMagick
## find my name and real current directory
PROGNAME=`type $0 | awk '{print $3}'`  # search for executable on path
PROGDIR=`dirname $PROGNAME`            # extract directory of program
PROGNAME=`basename $PROGNAME`          # base name of program
[ "$PROGDIR" == "." ] && PROGDIR=`cd $PROGDIR && pwd || echo $PROGDIR`
## Fully qualify directory path (remove relative components and symlinks)
## WARNING: The "bash" "pwd" builtin does not resolve symbolic links
## "sh" (as a link to "bash") also does not,   but "csh" does handle it.
## Symbolic link removal however is not critical.
ORIGDIR=`pwd`                                 # original directory (builtin)
PROGDIR=`cd $PROGDIR && pwd || echo $PROGDIR` # program directory
## Results...
##    $ORIGDIR    -- where the users was when called
##    $PROGDIR    -- script directory location (and now current directory)
##    $PROGNAME   -- This scripts executable name
# Get the fully qualified path to the script
case $0 in
        SCRIPT="$0"
        PWD=`pwd`
        SCRIPT="$PWD/$0"
esac
## Change spaces to ":" so the tokens can be parsed.
SCRIPT=`echo $SCRIPT | sed -e 's; ;:;g'`
## Get the real path to this script, resolving any symbolic links
TOKENS=`echo $SCRIPT | sed -e 's;/; ;g'`
REALPATH=
for C in $TOKENS; do
    REALPATH="$REALPATH/$C"
    while [ -h "$REALPATH" ] ; do
        LS="`ls -ld "$REALPATH"`"
        LINK="`expr "$LS" : '.*-> \(.*\)$'`"
        if expr "$LINK" : '/.*' > /dev/null; then
            REALPATH="$LINK"
        else
            REALPATH="`dirname "$REALPATH"`""/$LINK"
        fi
    done
done
# Change ":" chars back to spaces.
REALPATH=`echo $REALPATH | sed -e 's;:; ;g'`
[ "`basename $REALPATH`" == "." ] && \
    REALPATH="`echo $REALPATH | awk '{$0=substr($0,1,length($0)-2); print $0}'`"
# Change the current directory to the location of the script
PROGDIR="`cd $REALPATH && pwd || echo $PROGDIR`"
cd $PROGDIR
## Write error log message and exit
err(){
    local write_err="/sbin/log_tool -t2 -uSystem -p127.0.0.1 -mlocalhost -a"
    [ -n "$1" ] && local message="$NAME ${1:-"Unknown Error"}" && $write_err "$message"
    echo -e "\n\n [!] $message"
    exit 1
## Keep old PATH...
OLD_PATH=$PATH
## BASIC SETTINGS
PHP_INI_EXTENSION_DIR="/mnt/ext/opt/apache/modules"
PHP_INI_CLI_EXT_DIR="/opt/lib/php/extensions"
_opt_php_ini="/opt/etc/php.ini"
_sys_php_ini="/mnt/HDA_ROOT/.config/php.ini"
## Get volume and .qpkg directory
publicdir=`/sbin/getcfg Public path -f /etc/config/smb.conf`
qpkgdir=`cd $publicdir && cd ../.qpkg && pwd`
base=$qpkgdir/$QNAME
## Who Am I?
USER=`whoami`
[[ $USER != "admin" ]] && echo "STOP: sorry $USER user shall be admin" && exit
echo "
:: $NAME (for QNAP TurboNAS) installer [2013-08-03] ::
.. written by Silas Mariusz Grzybacz www.qnapclub.pl
Hello $USER ..."
## Install me to .qpkg
installMe(){
    [ ! -d "$base" ] && mkdir -p $base
    local _dir1=`cd $PROGDIR && pwd || echo $PROGDIR`
    local _dir2=`cd $base && pwd || echo $base`
    if [ "$_dir1" != "$_dir2" ]; then
        rm -rf $base
        mkdir -p $base
        cd $base
        echo -e "\n\n. Installing me \n    (from) $_dir1 \n   >> (to) $_dir2"
        cp -af "$_dir1/$PROGNAME" "$_dir2/$PROGNAME"
        chmod +x "$base/$PROGNAME"
    fi
## Check for Optware/IPKG QPKG
needIpkg(){
    type -f ipkg 2>&1 >/dev/null
    INSTALLED_IPKG=$?
    if [ $INSTALLED_IPKG -ne 0 ] || [ ! -f "/opt/bin/ipkg" ] || [ ! -x "/opt/bin/ipkg" ]; then
        err "Cannot find Optware/IPKG! Please install and enable it first."
    fi
updateIpkg(){
    echo -e "\n\n. Update Optware repository.
    /opt/bin/ipkg update 2>&1 >/dev/null
    RETVAL_1=$?
installDeps(){
    echo -e "\n\n. Install dependencies and build tools...
    /opt/bin/ipkg   install at autoconf automake bc binutils bzip2 \
            coreutils diffutils findutils freetype gawk gcc getopt \
            gettext glib grep gzip libcurl libcurl-dev libjpeg \
            libmemcache libpng libsigc++ libstdc++ libtiff libtool \
            libxml2 libxslt make m4 memcached patch patchutils \
            pcre pcre-dev perl php php-curl php-dev php-gd \
            php-iconv php-pear pkgconfig re2c readline sed tar \
            textutils tree tz util-linux wget which whois yasm zip \
            zlib 2>&1 >/dev/null
    RETVAL_2=$?
    if [ $RETVAL_1 -ne 0 ] || [ $RETVAL_2 -ne 0 ]; then
        err "Dependencies install failed! (IPKG)"
    fi
compileLibMagick(){
    echo -e "\n\n. Looking for libMagick...
    #/sbin/ldconfig -v /opt/lib 2>/dev/null | grep libMagick
    #RETVAL=$?
    ipkg install imagemagick || err "$PROGNAME:  Error on line $LINENO."
    RETVAL=0
    if [ $RETVAL -ne 0 ]; then
        echo -e "\n\n. Downloading latest version of ImageMagick library...
#       wget -q ftp://sunsite.icm.edu.pl/packages/ImageMagick/ImageMagick.tar.gz \
#            || err "$PROGNAME:  Error on line $LINENO."
        wget -q ftp://sunsite.icm.edu.pl/packages/ImageMagick/ImageMagick-6.8.6-7.tar.gz \
            -O ImageMagick.tar.gz || err "$PROGNAME:  Error on line $LINENO."
        tar zxf ImageMagick.tar.gz || err "$PROGNAME:  Error on line $LINENO."
        rm ImageMagick.tar.gz  || err "$PROGNAME:  Error on line $LINENO."
        SRCDIR=`ls -1 | grep ImageMagick-`
        cd $SRCDIR || err "$PROGNAME:  Error on line $LINENO."
        # Compiler options
        export CC="gcc -std=gnu99 -std=gnu99"
        export CFLAGS="-g -O2 -Wall -pthread"
        export CPP="gcc -E"
        export CPPFLAGS="-O2 -pipe -I/opt/include"
        export CXX="g++"
        export CXXFLAGS="-g -O2 -pthread"
        export DEFS="-DHAVE_CONFIG_H"
        export LDFLAGS="-L/opt/lib -Wl,-rpath,/opt/lib -Wl,-rpath-link,/opt/lib"
        export LD_LIBRARY_PATH=/opt/lib
        echo -e "\n\n. Installing: $SRCDIR (1: configure)
        ./configure --prefix=/opt --disable-openmp --without-perl  \
                --without-x --with-zlib --with-jpeg --with-png \
                --with-tiff --with-freetype --without-gslib    \
                --with-modules --enable-shared --enable-static \
                --with-sysroot=/opt                            \
        echo -e "\n\n. Installing: $SRCDIR (2: compiling. This may take a while...)
        make || err "$PROGNAME:  Error on line $LINENO."
        echo -e "\n\n. Installing: $SRCDIR (3: copying library files to /opt)
        make install || err "$PROGNAME:  Error on line $LINENO."
        cd ..
        rm -rf $SRCDIR || err "$PROGNAME:  Error on line $LINENO."
    fi
linkLibMagickIncludes(){
    # Linking Includes
    _t="/opt/include/ImageMagick"
    [ ! -L "$_t" ] && ln -sf /opt/include/ImageMagick-6 $_t
    _t="/opt/include/Magick++"
    [ ! -L "$_t" ] && ln -sf /opt/include/ImageMagick/Magick++ $_t
    _t="/opt/include/magick"
    [ ! -L "$_t" ] && ln -sf /opt/include/ImageMagick/magick $_t
    _t="/opt/include/wand"
    [ ! -L "$_t" ] && ln -sf /opt/include/ImageMagick/wand $_t
    _t="/opt/include/Magick++.h"
    [ ! -L "$_t" ] && ln -sf /opt/include/ImageMagick/Magick++.h $_t
compileImagick(){
    echo -e "\n\n. Looking for imagick.so...
    if [ ! -f "/opt/lib/php/extensions/imagick.so" ] || [ ! -x "/opt/lib/php/extensions/imagick.so" ]; then
        echo -e "\n\n. Downloading imagick source...
        wget -q http://pecl.php.net/get/imagick-3.0.1.tgz -O imagick.tgz \
        tar zxf imagick.tgz || err "$PROGNAME:  Error on line $LINENO."
        rm imagick.tgz package.xml || err "$PROGNAME:  Error on line $LINENO."
        SRCDIR=`ls -1 | grep imagick-`
        # Compiler options
        export CPP="gcc -E"
        export CXX="g++"
        echo -e "\n\n. Installing: $SRCDIR (1: phpize)
        /opt/bin/phpize || err "$PROGNAME:  Error on line $LINENO."
        echo -e "\n\n. Installing: $SRCDIR (2: configure)
        ./configure PREFIX=/opt/bin --enable-static --enable-static \
                --with-libdir=/opt/lib                          \
                --with-php-config=/opt/bin/php-config           \
                --with-imagick=/opt                             \
        echo -e "\n\n. Installing: $SRCDIR (3: compiling. This may take a while...)
        echo -e "\n\n. Installing: $SRCDIR (4: copying library files to /opt)
        cd ..
    else
        echo "        /opt/lib/php/extensions/imagick.so"
    fi
makeLinks(){
    # Installing files
    echo -e "\n\n. Installing imagick.so module file.
    MODULE=/opt/lib/php/extensions/imagick.so
    if [ ! -f "$MODULE" ]; then
        err "Module imagick.so not found... Installation failed!"
    fi
    cp -af $MODULE $PHP_INI_EXTENSION_DIR
    # Create libraries links
    [ ! -L "/usr/lib/libMagickCore.so.3" ] && \
        ln -sf /usr/lib/libMagickCore.so.3.0.0 \
    [ ! -L "/usr/lib/libMagickCore.so.3.0.0" ] && \
        ln -sf /mnt/ext/opt/ImageMagick/usr/lib/libMagickCore.so.3.0.0 \
    [ ! -L "/usr/lib/libMagickWand.so.3" ] && \
        ln -sf /usr/lib/libMagickWand.so.3.0.0 \
    [ ! -L "/usr/lib/libMagickWand.so.3.0.0" ] && \
        ln -sf /mnt/ext/opt/ImageMagick/usr/lib/libMagickWand.so.3.0.0 \
    [ ! -L "/usr/local/sbin/convert" ] && \
        ln -sf /mnt/ext/opt/ImageMagick/usr/local/sbin/convert \
    [ ! -L "/usr/local/sbin/identify" ] && \
        ln -sf /mnt/ext/opt/ImageMagick/usr/local/sbin/identify \
    [ ! -L "/usr/sbin/convert" ] && \
               /usr/sbin/convert
    [ ! -L "/usr/sbin/identify" ] && \
               /usr/sbin/identify
installAsQPKG(){
    # Install me as QPKG App
    echo -e "\n\n. Installing $QNAME as QPKG-App and imagick-module as extension...
    /sbin/setcfg $QNAME Name "$QNAME" -f /etc/config/qpkg.conf
    /sbin/setcfg $QNAME Version "1.0" -f /etc/config/qpkg.conf
    /sbin/setcfg $QNAME Author "Silas Mariusz" -f /etc/config/qpkg.conf
    /sbin/setcfg $QNAME Date `date +%F` -f /etc/config/qpkg.conf
    /sbin/setcfg $QNAME QPKG_File "${QNAME}.qpkg" -f /etc/config/qpkg.conf
    /sbin/setcfg $QNAME Shell "$base/$PROGNAME" -f /etc/config/qpkg.conf
    /sbin/setcfg $QNAME Install_Path "$base" -f /etc/config/qpkg.conf
    /sbin/setcfg $QNAME Enable "TRUE" -f /etc/config/qpkg.conf
    # Create control script links
    [ -L "/etc/init.d/$PROGNAME" ] && rm -f "/etc/init.d/$PROGNAME"
    [ -L "/etc/rcS.d/QS104$PROGNAME" ] && rm -f "/etc/rcS.d/QS104$PROGNAME"
    [ -L "/etc/rcK.d/QK104$PROGNAME" ] && rm -f "/etc/rcK.d/QK104$PROGNAME"
    [ ! -L "/etc/init.d/$PROGNAME" ] && \
        ln -sf "$base/$PROGNAME" "/etc/init.d/$PROGNAME"
    [ ! -L "/etc/rcS.d/QS104$PROGNAME" ] && \
        ln -sf "$base/$PROGNAME" "/etc/rcS.d/QS104$PROGNAME"
    [ ! -L "/etc/rcK.d/QK104$PROGNAME" ] && \
        ln -sf "$base/$PROGNAME" "/etc/rcK.d/QK104$PROGNAME"
    cp -f "/home/httpd/RSS/images/no_qpkg_icon_64.gif" \
                   "$base/no_qpkg_icon_64.gif"
    cp -f "/home/httpd/RSS/images/no_qpkg_icon_64_gray.gif" \
                   "$base/no_qpkg_icon_64_gray.gif"
    cp -f "/home/httpd/RSS/images/no_qpkg_icon_80.gif" \
                   "$base/no_qpkg_icon_80.gif"
          "/home/httpd/RSS/images/${QNAME}_64.gif"
          "/home/httpd/RSS/images/${QNAME}_64_gray.gif"
          "/home/httpd/RSS/images/${QNAME}_80.gif"
applyImagick(){
    # Create include link
    [ ! -d "/etc/config/php" ] && mkdir -p "/etc/config/php"
    if [ ! -L "/etc/config/php/imagick" ] || [ ! -d "/etc/config/php/imagick" ]; then
        ln -sf /opt/include/php/ext/imagick /etc/config/php/imagick
    fi
    cat $_opt_php_ini | grep "/etc/config/php:/opt/include/php/ext:/opt/share/pear:/php/includes" >/dev/null
    RETVAL=$?
        _opt_php_include=`/sbin/getcfg PHP include_path -d "." -f $_opt_php_ini | tr -d "\""`
        /sbin/setcfg PHP include_path "\""$_opt_php_include:/etc/config/php:/opt/include/php/ext:/opt/share/pear:/php/includes\""" -f $_opt_php_ini
    fi
    cat $_opt_php_ini | grep "/opt/lib/php/extensions" >/dev/null
    RETVAL=$?
        _opt_php_extension=`/sbin/getcfg PHP extension_dir -d "." -f $_opt_php_ini | tr -d "\""`
        /sbin/setcfg PHP extension_dir "\""$_opt_php_extension:/opt/lib/php/extensions\""" -f $_opt_php_ini
    fi
    cat $_sys_php_ini | grep "/opt/include/php/ext:/opt/share/pear:/php/includes" >/dev/null
    RETVAL=$?
        _sys_php_include=`/sbin/getcfg PHP include_path -d "." -f $_sys_php_ini | tr -d "\""`
        /sbin/setcfg PHP include_path "\""$_sys_php_include:/opt/include/php/ext:/opt/share/pear:/php/includes\""" -f $_sys_php_ini
    fi
    #cat $_sys_php_ini | grep "/opt/lib/php/extensions:$PHP_INI_EXTENSION_DIR" >/dev/null
    cat $_sys_php_ini | grep "/usr/local/apache/modules" >/dev/null
    RETVAL=$?
        _sys_php_extension=`/sbin/getcfg PHP extension_dir -d "." -f $_sys_php_ini | tr -d "\""`
        /sbin/setcfg PHP extension_dir "\""$_sys_php_extension:/usr/local/apache/modules\""" -f $_sys_php_ini
    fi
    cat $_opt_php_ini | grep "extension = imagick.so" >/dev/null
    RETVAL=$?
        cp -af $_opt_php_ini ${_opt_php_ini}.bak
        echo "[Imagick]
extension = imagick.so" >> $_opt_php_ini
    fi
    cat $_sys_php_ini | grep "extension = imagick.so" >/dev/null
    RETVAL=$?
        cp -af $_sys_php_ini ${_sys_php_ini}.bak
        echo "[Imagick]
extension = imagick.so" >> $_sys_php_ini
    fi
case "$1" in
    start)
        needIpkg
        makeLinks
        applyImagick
        # Restart HTTPD server
        echo -e "\n\n. Restarting Qhttpd server $_q
        /etc/init.d/Qthttpd.sh restart
    stop)
        # Thereo is no stop
        echo "Nothing to do."
    restart)
        $0 stop
        $0 start
    install)
        needIpkg
        updateIpkg
        installDeps
        installMe
        # Set strict PATH to required tools
        export PATH=/opt/bin:/opt/sbin
        [ -d "temp.$QNAME" ] && rm -rf "temp.$QNAME"
        mkdir -p "temp.$QNAME"
        cd "temp.$QNAME"
        compileLibMagick
        compileImagick
        cd ..
        installAsQPKG
        makeLinks
        applyImagick
        export PATH=$OLD_PATH:$PATH
        echo -e "\n\n Usage: $0 {install|start|stop}"
esac
    echo -e "\n\n. Bye bye...
Reactions: kaktus
  • TS-219P+
  • 1 GbE
  • ostatni możliwy do używania
Skrypt powoduje dysfunkcję serwera NAS, przynajmniej u mnie. Czekam na naprawę.
  • TS-219P+
  • 1 GbE
Jak mam dać, kiedy sam nie mam???????????????????????
spółdzielnia pracy ODNOWA mnie czekaNo to obczajam wyniki i za moment chwila prawdy ...
;DPod względem wykrywania zachowana poprzednia funkcjonalność:
phpinfo -> brak detekcji imagemagick
aplikacja -> brak detekcji
/usr/local/apache/bin/php -m -> brak detekcji
/opt/bin/php -m -> wykrywa imagick
reboot -> w trakcieQTS już nie ma czkawki ;)
beep.beep..beep...beep....beep.....beeep
chyba przetrawił i mu się już nie odbija. ;-D
Czyli skrypt już działa poprawnie i instaluje ImageMagick. Wygląda na to, że wersja php na platformie ARM nie przyjmuje extensions. Nie pozostaje Ci nic innego jak spróbować podmienić php na te z Opatware.
mv /usr/local/apache/bin/php /usr/local/apache/bin/php.qnap && ln -sf /opt/bin/php /usr/local/apache/bin/php
  • TS-219P+
  • 1 GbE
Stan bieżący:
PHPinfo -> brak detekcji imagemagick
/usr/local/apache/bin/php -m -> wykrywa imagick - bo musi :)
PATH ma "nowe lokalizacje"
PHPinfo już nie
@kaktus FYI:
  1. Zrób sobie skrypt w /share/Public o nazwie phpreplace.sh
    touch /share/Public/phpreplace.sh
    chmod +x /share/Public/phpreplace.sh
  2. Wklej do niego:
    #!/bin/sh
    php_qts="/usr/local/apache/bin/php"
    php_opt="/opt/bin/php"
    if [ ! -f "${php_qts}.orig" ] && [ -f "$php_qts" ]; then
            mv "$php_qts" "${php_qts}.orig"
            ln -sf "$php_opt" "$php_qts"
            /opt/bin/php -m
            echo "(0) php replaced successfully!"
    else
            echo "(127) Failed to replace php. ${php_qts}.orig already exist or missing ${php_qts}."
    fi
  3. Zobacz czy skrypt działa poprawnie.
    . /share/Public/phpreplace.sh
    Jeśli poprawnie podmienił php to wstaw uruchomienie skryptu na koniec sekwencji startowej do /etc/init.d/ImageMagick.sh czyli za linią nr. 390 (applyImagick)
Dziękuje za uwagę! :p
  • TS-219P+
  • 1 GbE
Tak się składa że w końcu ;) przy okazji innej sprawy zajrzałem w log i zobaczyłem takiego babola
imagick-module Cannot find Optware/IPKG! Please install and enable it first.
po stalinizacji dodatku, występuje po każdorazowym uruchomieniu NAS. Dodatek sam przecież wszystko ładnie instaluje, a ipkg funkcjonuje prawidłowo. Jest możliwe, że jeszcze się coś nie poinicjowało i po/w trakcie startowania robi się dysfunkcja?
To Ty logów nie czytasz?
Wrzuć na początek:
export PATH="$PATH:/opt/bin:/opt/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games"
sleep 10
i zmień w skrypcie i w /etc/rc.* nazwy linków QS104 na QS105 i QK104 na QK105.
  • TS-219P+
  • 1 GbE
hehehe ostatnio nas mało pracował i nie było powodu zaglądać ;)
te games pewno bardzo niezbędne jest :D
logi NAS ostatnio zamieniłem na logi forum jednego :p
przetestuje się
  • TS-219P+
  • 1 GbE
Po wystartowaniu NAS $PATH jest następujące
# echo $PATH
/bin:/sbin:/usr/bin:/usr/sbin:/usr/bin/X11:/usr/local/sbin:/opt/bin:/opt/sbin
Kaktus. Podstawy linuxa...
Już tłumacze...
To co Ty dostaniesz w shellu jako PATH zależy od tego co masz w /etc/profile
A to, że wklepiesz export, o którym wspominam dla skryptu startowego Imagick będzie dostępne dla aplikacji uruchamianych z tego skryptu wyłącznie.
