Pomoc Problems - UI tabs are mixed and too long after disabling ratio tab
majkimajki
3 Lipiec 2018
10
Couple problems;
You can't sort the tabs on the top, look closely at what happens. This is irritating.
That tabs are all mixed up.
aimage.ibb.co_jPryL9_Fire_Shot_Capture_109_ru_Torrent_v3_8_http_192_168_100_16_6009_ui_rtorrent.png
It does delete your settings, and deletes rss channels. All the front page settings have to be setup again.
Hi,
No - nothing of the sorts.
The first 5 columns work well, the problems seems to come up with the filled in column with colors.
Will test more.
edit;
temp solution is to add the ratio column.
Have you tested with trying to delete the ratio column, see what happens?
