Firmware version: 4.3.6
Model name: QNAP TS-251+
hi all just recently installed rtorrent pro very happy with most of it. got a question though. im using expressvpn when i bind network interface just the default gate way my port 42000 goes green and my download speeds are better plus i have alot more seeds etc. i use QVPN and add my express VPN openvpn config it connects and works fine. when i bind the interface for my QVPN express vpn i reload rtorrent and the port is then closed. my router is forwarded. ive been trying to change settings etc but im not having any luck for rtorrent to display the port as opened. in QVPN my openvpn profile uses UDP port 1195 dont know if that wil help but i thought id give you as much information as possible. ive also forwared the ports through qnapcloud. my modem supports UNPN and is currently on etc
