Download [RC1] QTS 4.2.0 Build 0902 | ARM & x86
Silas Mariusz
rm -rf /
Help us, GOD!
10 213
31
2 317
153
39
forum.qnap.net.pl
QTS4.2.0 Build 0902
[Bug Fixes]
- Fixed Change Password vulnerability.
- Fixed Apple Networking vulnerability.
- Fixed multiple OpenSSH vulnerabilities (CVE-2015-5600 and other three).
- Fixed WebDAV vulnerability.
- If MySQL fails, the connection of the Qsync Client will act abnormally.
- Pools/volumes created in QTS 4.2.0 will be invalidated if you downgrade to a previous firmware.
- If a WLAN is set as the gateway on a TS-x12 series model, restarting the NAS will cause the gateway to change to LAN1
- The TS-269H cannot connect to Sony SRS-X2 Bluetooth speakers.
- Some MP3s are not audible when playing on Music Station.
- If you check then uncheck the SMB Encryption option in shared folders, the option will still be checked.
- After installing HD Station then rebooting the NAS, encrypted volumes will be stuck in a "Loading" state.
- The NAS will be unstable when enabling the domain controller and changing Windows ACL permissions.
- System Connection logs will be incorrect for opening shared links and downloading files from shared links.
- After reverting to a snapshot using SnapAgent, the Esxi datastore will be empty.
- After NetBak finishes backing up, the VSS should be deleted by the system in SnapAgent.
- TS-x31+ series models fail to download files after downloading torrent files.
- When streaming media files to the DLNA player, if you drag the progress bar in Media Viewer the NAS will exit the play function.
- When accessing QTS using an iPhone 6, the login page will not remember users' log in details.
- Normal users can find QPKGs via search.
- Fails to show personal photos after changing the image.
- HD Station will fail to be installed if Container Station is installed and activated before updating it.
- The connection to a cloud drive via samba in File Station will cause the NAS to freeze if you click on a drive that has over 120 subfolders.
- An error message will be displayed if you remove a connection to Amazon in File Station and then attempt to connect to it again.
- A connection cannot be created if you log in to File Station with a manually-entered IP address.
- Downloading the key file in Encryption Folder will display an Internal Server Error.
- Fails to connect to Box in File Station.
- The [Expand Capacity] button does not work when clicked on.
- When importing users from DC, the password preview will show an incorrect password if it has characters after the "<".
- After expanding capacity, the pool information will still say it's full on the dashboard.
- Moving folder A in Multimedia to a Public folder in File Station will take an excessive amount of time.
- Backup jobs cannot be created with the same name as deleted jobs.
- Checking the file system will result in errors after Gmail Backup is installed.
- User-customized databases will be unable to upgrade to the correct version after you upgrade from 4.1.4 to 4.2.0.
- The Play option is missing when right clicking on media files found by the search function.
[Download]
http://eu1.qnap.com/Storage/HS-210TurboNAS/HS-210_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/HS-251/HS-251_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/IS-400/IS-400_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/SS-439ProTurboNAS/SS-439_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/SS-469/SS-469_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/SS-839ProTurboNAS/SS-839_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/SS-EC1279U-SAS-RP/SS-1279U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/SS-EC1879U-SAS-RP/SS-1879U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/SS-EC2479U-SAS-RP/SS-2479U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-1079ProTurboNAS/TS-1079_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-110TurboNAS/TS-110_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-112TurboNAS/TS-112_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-119TurboNAS/TS-119_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-120TurboNAS/TS-120_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-121TurboNAS/TS-121_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-1269U-RP/TS-1269U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-1270U-RP/TS-1270U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-1279U-RP/TS-1279U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-1679U-RP/TS-1679U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-210TurboNAS/TS-210_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-212TurboNAS/TS-212_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-219TurboNAS/TS-219_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-220TurboNAS/TS-220_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-221TurboNAS/TS-221_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-239HTurboNAS/TS-239H_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-239ProII+TurboNAS/TS-239PROII+_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-239ProIITurboNAS/TS-239PROII_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-239ProTurboNAS/TS-239_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-259ProTurboNAS/TS-259_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-269HTurboNAS/TS-269H_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-269ProTurboNAS/TS-269_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-410TurboNAS/TS-410_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-410UTurboNAS/TS-410U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-412TurboNAS/TS-412_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-412UTurboNAS/TS-412U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-419PTurboNAS/TS-419P_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-419UTurboNAS/TS-419U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-420TurboNAS/TS-420_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-420UTurboNAS/TS-420U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-421TurboNAS/TS-421_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-421UTurboNAS/TS-421U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-439ProII+TurboNAS/TS-439PROII+_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-439ProIITurboNAS/TS-439PROII_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-439ProTurboNAS/TS-439_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-439UTurboNAS/TS-439U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-459ProTurboNAS/TS-459_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-459UTurboNAS/TS-459U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-469ProTurboNAS/TS-469_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-469U-RP/TS-469U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-470ProTurboNAS/TS-470_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-470U-RP/TS-470U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-509ProTurboNAS/TS-509_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-559ProTurboNAS/TS-559_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-563/TS-563_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-569ProTurboNAS/TS-569_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-639ProTurboNAS/TS-639_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-659ProTurboNAS/TS-659_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-669ProTurboNAS/TS-669_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-670ProTurboNAS/TS-670_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-809ProTurboNAS/TS-809_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-809U-RP/TS-809U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-859ProTurboNAS/TS-859_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-859U-RPTurboNAS/TS-859U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-869ProTurboNAS/TS-869_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-869U-RP/TS-869U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-870ProTurboNAS/TS-870_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-870U-RP/TS-870U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-879ProTurboNAS/TS-879_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-879U-RPTurboNAS/TS-879U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-X31/TS-X31_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-X31+/TS-X31+_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-X31U/TS-X31U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-X51/TS-X51_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-X51U/TS-X51U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-X53/TS-X53_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-X53S/TS-X53S_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-X53U/TS-X53U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-X80/TS-X80_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TS-X80U/TS-X80U_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TVS-X63/TVS-X63_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TVS-X71/TVS-X71_20150902-4.2.0.zip
http://eu1.qnap.com/Storage/TVS-X71U/TVS-X71U_20150902-4.2.0.zip
Hyhy :D
Ale jakby co to wszystkie w/w działają
Sprawdziłem i znowu wycofałem do 716, bo jest ten sam problem co w poprzednim buildzie czyli:
.... moje dwa zewnętrzne dyski USB, są teraz teoretycznie widoczne, bo przy obu widnieje napis "Nie zainicjowany". Jedyną metodą "zainicjowania" jest chyba sformatowanie, bo nic innego nie widzę (chodzi mi oczywiście o możliwości z poziomu Qnapa). Co ciekawe pokazywany jest prawidłowo system plików (NTFS) i zajętość (ale tylko w komunikacie o podłączeniu dysku, bo potem .... jak widać), jednak dyski są niewidoczne w File station, a także nie są udostępniane, jak to było przed update.....
Po powrocie do builda 0716 - dyski znowu są widoczne prawidłowo.
A wygląda to tak:
build 902
build 716
Zrób update do QTS 4.2 RC1. Udostępnij FAQ SSH oraz login i hasło admina do mnie na PM. Główny menadżer RD z QNAP chce zalogować się i sprawdzić co się dzieje.
Zmiany, które widzę zaraz po zalogowaniu na nowej wersji to AppCenter zmieniło ikonę i ciekawy komunikat po wejściu
ten komunikat to mnie denerwuje bo wyświetla się zawsze jak się loguje...
EDIT
Nie działa mi Download station...znikła ikonka w pulpitu i paska bocznego a w aplikacion jak chce uruchomić to wyświetla się komunikat Acces danied......odinstalowałem i na nowo zainstalowałem apke ale problem nadal ten sam....co robić ?
Jest nowy build 0910 - tego komunikatu już nie ma - to pierwsza rzucająca się w oczy zmiana :)
Jestem w ciepłych krajach na urlopie, ale i tak się cieszę ;)
Wysłane z mojego M6752 przy użyciu Tapatalka
