I have been using rtorrent on my Qnap TS-653D and it has been working great. Early this morning I went to use it again (worked last night) and the web interface causes a refused to connect error.
I tried to start it manually and it says (err!) rtorrent: Port Torrent: 21041 is already in use. Which rtorrent is the only app using this port. I tried to restart the whole system but no change. I even upgraded to the latest firmware but no dice.
Let me know if you need anything else
Firmware version: 4.5.1.1480
Model name: QNAP TS-653D
/etc/init.d/rtorrent.sh start
(info) rtorrent: [Rdownload] share link found and operational.
(info) rtorrent: Tuning network performance
(info) rtorrent: Applying immediatly network tweak also for idle existing TCP connections
(warn) rtorrent: Suggestion: Define custom download location path. Please read this guide: KB: [URL='http://qnapclub.pl/kb/24910']Network Share - How-To change downloaded data path to another disk volume[/URL]
(info) rtorrent: Creating label note: /share/Rdownload/watch/~~Readme.txt
(info) rtorrent: Creating label note: /share/Rdownload/downloads/~~Readme.txt
(info) rtorrent: Creating label note: /share/Rdownload/complete/~~Readme.txt
(info) rtorrent: Increasing file watch instances - inotify
fs.inotify.max_user_watches = 1048576
(info) rtorrent: Fix no more PTYs issue
(info) rtorrent: Creating link: /usr/bin/rtorrent
(info) rtorrent: Creating link: /usr/bin/htop
(info) rtorrent: Creating link: /usr/bin/multitail
(info) rtorrent: Creating link: /usr/bin/filebot
(info) rtorrent: Creating link: /usr/bin/filebot-postprocess.sh
(info) rtorrent: Creating link: /usr/bin/rtorrent.exe
(info) rtorrent: TZ: US/Central
init.d/rtorrent: Force Stop engine program: rtorrent
(info) rtorrent: Port SCGI: 19000 is available.
(info) rtorrent: Port Plain-http-Web: 6009 is available.
(info) rtorrent: Port SSL-https-Web: 6008 is available.
(info) rtorrent: Port DHT: 19220 is available.
[~] # /etc/init.d/rtorrent.sh enable
(info) rtorrent: Program located in PROGDIR: /share/CE_CACHEDEV1_DATA/.qpkg/rtorrent and executed at ORIGDIR: /root
(info) rtorrent: auto launch enabled.
[~] # /etc/init.d/rtorrent.sh start
(err!) rtorrent: application not started, but watchdog execution detected. Please report this error 2057:0.9.7-A825 to package maintainer [EMAIL]silas@qnapclub.pl[/EMAIL]
