Pomoc rtorrent-Pro 0.9.6-1017 Relaunching...!
2bad2good
10 Marzec 2018
rtorrent-Pro log
[05.11.2018 18:53:45] WebUI started.
[05.11.2018 18:53:45] There is no connection with rTorrent. Check if it is running. Check that the parameters $ scgi_port and $ scgi_host in the config.php file match the value of the variable scgi_port in the configuration file rTorrent.
NAS log
2018/11/05 19:03:01 rtorrent 127.0.0.1 --- --- (warn) rtorrent: watchdog svc: rtorrent is down. Relaunching...
Firmware version: 4.3.5.0728 Build 20181013
Model name: QNAP TS-251+
