Pomoc rtorrent-pro + SSL = błędy??
goral87
14 Marzec 2016
58
10
localhost
TS-x73A
mam ustawione stałe wymuszanie SSL i tylko gdy zaloguję się do rtorrenta-pro (najnowsza wersja) co chwilę sypie mi błędami
przeglądarka Vivaldi (najnowsza wersja) a loguję się przez https://IP:6008/ui/rtorrent/
Number Type Date Time Users Source IP Computer name Content
20877 Warning 2018-10-10 22:15:01 rtorrent 127.0.0.1 localhost (warn) rtorrent: watchdog svc: monitorix is down. Relaunching...
20876 Warning 2018-10-10 22:14:01 rtorrent 127.0.0.1 localhost (warn) rtorrent: watchdog svc: monitorix is down. Relaunching...
20875 Warning 2018-10-10 22:13:01 rtorrent 127.0.0.1 localhost (warn) rtorrent: watchdog svc: monitorix is down. Relaunching...
20874 Warning 2018-10-10 22:12:01 rtorrent 127.0.0.1 localhost (warn) rtorrent: watchdog svc: monitorix is down. Relaunching...
20873 Warning 2018-10-10 22:11:01 rtorrent 127.0.0.1 localhost (warn) rtorrent: watchdog svc: monitorix is down. Relaunching...
20872 Warning 2018-10-10 22:10:01 rtorrent 127.0.0.1 localhost (warn) rtorrent: watchdog svc: monitorix is down. Relaunching...
20871 Warning 2018-10-10 22:09:01 rtorrent 127.0.0.1 localhost (warn) rtorrent: watchdog svc: monitorix is down. Relaunching...
20870 Warning 2018-10-10 22:08:01 rtorrent 127.0.0.1 localhost (warn) rtorrent: watchdog svc: monitorix is down. Relaunching...
20869 Warning 2018-10-10 22:07:01 rtorrent 127.0.0.1 localhost (warn) rtorrent: watchdog svc: monitorix is down. Relaunching...
20868 Warning 2018-10-10 22:06:01 rtorrent 127.0.0.1 localhost (warn) rtorrent: watchdog svc: monitorix is down. Relaunching...
20867 Warning 2018-10-10 22:05:01 rtorrent 127.0.0.1 localhost (warn) rtorrent: watchdog svc: monitorix is down. Relaunching...
20866 Warning 2018-10-10 22:04:01 rtorrent 127.0.0.1 localhost (warn) rtorrent: watchdog svc: monitorix is down. Relaunching...
oraz
[10.10.2018 22:17:02] Bad response from server: (0 [error,list])
[10.10.2018 22:17:02] Bad response from server: (0 [error,gethistory])
tak ma być czy to coś u mnie
Wersja oprogramowania Firmware: 4.3.5 Build 20181007
Model serwera: QNAP TS-451
Mam to samo ostrzeżenie. Wcześniej miałem tak na wersji bezpłatnej i teraz po zainstalowaniu wersji pro jest to samo...
Ostrzeżenie 2019/01/20 11:13:01 rtorrent 127.0.0.1 --- --- (warn) rtorrent: watchdog svc: monitorix is down. Relaunching...
TS-251 wersja 4.3.6.0805
mi pomogła aktualizacja rtorrent-pro
A masz włączonego Monitorixa manualnie?
Wyłącz go...
setcfg rtorrent svc_monitorix 0 -f /etc/config/qpkg.conf
i zainstaluj ostatnią wersje rtorrent-Pro 0117.
