Pomoc rtorrent-Pro manual and tutorial
JrCsG
31 Lipiec 2018
TS-x69L
Hi,
again a (maybe silly) question:
I bought rtorrent-Pro. :)
Before this program, I used Transmission. As I can see this program is a "bit" different. Where can I find a tutorial/help for the settings/using of the program?
There is no manual yet.
You should play with it a bit because it offers more than a Transmission and in the begining might be difficult to understand. But I can recommend you to use Advanced UI always.
All you need to know in the begining is to ...
- Use watch directory to start new torrents tasks. So just put .torrent file you wanna download into watch directory to start it automatically.
- Use labels inside watch directory. Put .torrent file inside of label/category directory like movie, tv, game and etc. If there is not enough categories, you can create them by creating a directory in watch...
Why not use QNAP VPN and then select proper interface from a Bind list?
