xtrem
TS-x53Be
Hi,
In the last update, you presented a new feature allowing to switch between multiple Rtorrent engine versions.
How can I see what is the current engine version that is being used?
Thanks
Bottom bar in the UI.
Thanks Silas Mariusz Silas Mariusz
The reason, that I have considered switching engines is because my speed dropped by 35% after I updated to version 0.9.x-0099
The question is if there is something that can be done or a setting that can be changed, to get the previous speed ?
  1. forum
