Tak jak w temacie, NAS nie widzi dysku twardego podłączonego pod dowolne usb. Poniżej logi. Dodam że inny dysk też usb 3.0 jest wykrywany bez najmniejszych problemów.
lsusb -v
dmesg
[~] # df -h
lsusb -v
Bus 003 Device 003: ID 1058:0748 Western Digital Technologies, Inc.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 3.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 9
idVendor 0x1058 Western Digital Technologies, Inc.
idProduct 0x0748
bcdDevice 10.25
iManufacturer 1 Western Digital
iProduct 2 My Passport 0748
iSerial 5 575836314336324C30363936
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 44
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 4 USB Mass Storage
bmAttributes 0x80
(Bus Powered)
MaxPower 224mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk (Zip)
iInterface 6 MSC Bulk-Only Transport
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0400 1x 0 bytes
bInterval 0
UNRECOGNIZED: 06 30 0f 00 00 00
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Status: 0x0000
(Bus Powered)
dmesg
[30842.169571] usb 3-1: new SuperSpeed USB device number 3 using etxhci_hcd_140522
[30842.210203] scsi5 : usb-storage 3-1:1.0
[30843.219972] scsi 5:0:0:0: Direct-Access WD My Passport 0748 1025 PQ: 0 ANSI: 6
[30843.242863] sg_alloc failed
[30843.250488] scsi 5:0:0:1: Enclosure WD SES Device 1025 PQ: 0 ANSI: 6
[30843.286556] sg_alloc failed
[~] # df -h
Filesystem Size Used Available Use% Mounted on
/dev/ramdisk 32.9M 16.3M 16.6M 50% /
tmpfs 64.0M 200.0k 63.8M 0% /tmp
/dev/sda4 371.0M 333.1M 37.9M 90% /mnt/ext
/dev/md9 509.5M 135.8M 373.7M 27% /mnt/HDA_ROOT
/dev/sda3 2.7T 1.2T 1.5T 44% /share/HDA_DATA
tmpfs 32.0M 0 32.0M 0% /.eaccelerator.tmp
