Autosub-qnap
Tutorial how to install autosub on a Qnap use at your own risk!
Download bootstrap ZIP file at https://code.google.com/p/autosub-bootstrapbill/source/browse/ or take the one from this git.
Create a directory autosub in
Download the
To make it runable:
Now save the Qnap config file before messing with it. Qnap config file:
SAVE THIS FILE BEFORE MAKING CHANGES! Insert the following at the bottom of the file:
You should now be able to start the program in your Qnap app center and open it in HTTP://yournasIP:8083
Go to the config page and save, this will create the default config file config.properties in
If you have upgraded your Qnap from V3.* to V4.* your path should be
Other projects:
Using napiprojekt client: https://github.com/hicolour/env-qnap
/share/CACHEDEV1_DATA/.qpkg/
Upload the content of the ZIP file and the config.properties
file to /share/CACHEDEV1_DATA/.qpkg/autosub
Download the
autosub.sh
file from this git and put it in /share/CACHEDEV1_DATA/.qpkg/autosub
To make it runable:
chmod +x autosub.sh
/mnt/HDA_ROOT/.config/qpkg.conf
INI:
[AutoSub]
Name = AutoSub
Version = 1.0
Enable = FALSE
QPKG_File = autosub.qpkg
Date = 2014-11-08
Shell = /share/CACHEDEV1_DATA/.qpkg/autosub/autosub.sh
Install_Path = /share/CACHEDEV1_DATA/.qpkg/autosub
WebUI = /
Author = Mve
Web_port = 8083
RC_Number = 133
/share/MD0_data/*
, when you reinstall the Qnap with the latest FW your path will be /share/CACHEDEV1_DATA
Other projects:
