Download [Beta 2] QTS 4.1.0 Build1128 SMB | TS-X69/X70/X79 [Leak/Non-Official]
Silas Mariusz
rm -rf /
Help us, GOD!
10 213
31
2 320
153
39
forum.qnap.net.pl
[Version]
4.1.0 Build1128
[Major Change List]
1. Storage utilization history
2. SAMBA v4: Secured data transmission, SMB2, SMB3 (partially supported)
3. Domain controller
4. NTP server
5. Supports external drive volume label for EXT3 & EXT4 file systems. The label also represents the shared folder naming.
[Beta Firmware Disclaimer]
DISCLAIMER OF WARRANTIES
THE BETA FIRMWARE ANNOUNCED BY QNAP IS PROVIDED ON A TRIAL BASIS ONLY AND WITHOUT WARRANTY OF ANY KIND. YOU ARE SUGGESTED NOT TO USE THE BETA FIRMWARE FOR ANY CRITICAL PURPOSE. BY DOWNLOADING THE BETA FIRMWARE IMAGES, YOU EXPRESSLY AGREE THAT THE USE OF THE FIRMWARE IS AT YOUR OWN RISK AND DISCRETION. YOU WILL BE SOLELY RESPONSIBLE FOR ANY DAMAGE TO YOUR NAS, COMPUTER SYSTEM, OR OTHER DEVICES OR ANY FORM OF DATA LOSS OR DAMAGE CAUSED BY DOWNLOADING OR USING THE FIRMWARE. QNAP DOES NOT GUARANTEE THERE IS NO ERROR OR BUG IN THE FIRMWARE, OR ANY KNOWN OR REPORTED ERRORS WILL BE CORRECTED.
QNAP EXPRESSLY DISCLAIMS ALL WARRANTIES OF ANY KIND, WHETHER EXPRESS OR IMPLIED, INCLUDING, BUT NOT LIMITED TO THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
LIMITATION OF LIABILITY
IN NO EVENT WILL QNAP BE LIABLE FOR ANY DAMAGE WHATSOEVER (INCLUDING WITHOUT LIMITATION DAMAGES RELATING TO LOST REVENUES OR PROFITS, LOST DATA, WORK STOPPAGE, COMPUTER FAILURE OR MALFUNCTION) RESULTING FROM OR IN ANY WAY RELATED TO THE USE OF THE BETA FIRMWARE , EVEN IF QNAP HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH DAMAGES AND REGARDLESS OF THE LEGAL THEORY ON WHICH SUCH DAMAGES ARE BASED.
[Note]
This is leaked firmware from QNAP!
[Download]
Ask for...
Dzięki
Niestert komunikat - File not found :(
Ostatnio edytowane:
Ktoś może wie co stało się z YouTube z HD Station? W tej kompilacji go nie ma.
W poprzednich wersjach było tak, że pod HD Station można było sobie dodawać poszczególne funkcjonalności czyli XBMC, Chrome, youtube czy mynas. W tej nowej wersji na liście w ogóle nie ma youtube. Zastanawiam się czy to od nowej wersji HD Station, która się pojawiła razem z QTS 4.1.0 przestali to dodawać czy też, gdzieś przez przypadek przepadła paczka z youtube.
Spróbuje jeszcze raz przeinstalować całe HD Station z tym, że już to robiłem bo jest jakiś dziwny bug w XBMC, że po wczytaniu nowego firmware po uruchomieniu filmu zawiesza na chwilę całą aplikację. Pomogło mi jedynie przeinstalowanie HD Station (miałem tak zarówno przy 4.0.3, 4.0.4 jak i 4.1.0).Po sprawdzeniu instalacji HD Station od nowa nie ma możliwości zainstalowania youtube. Z tego co znalazłem to youtube można sobie zainstalować ręcznie, ale tylko dla sprzętu x70. Bardzo nie ładnie ze strony QNAP - nie dość, że XBMC można updatowć do wyższej wersji też tylko na x70 to teraz jeszcze youtube....
Oczywiście biorę to pod uwagę i mam nadzieję, że w oficjalnej wersji jednak pojawi sie youtube.
TS-569 Pro proszę
Najnowszego buildu jeszcze nie zainstalowałem, natomiast miałem 4.1 z 1105 i obecnie mam 4.1 z 1112. W obu tych wersjach YouTube jest.
Sprawdzę dziś na build1128. Możesz podać jaką masz obecnie wersję HD Station ?
Reakcje: Silas Mariusz
Właśnie zainstalowałem build1128. HD Station 1.0.8 i YouTube jet tak samo jak wcześniej. Wszystko bez zmian.
  • Wow
Witam.
Ja na TS-269 PRO zainstalowałem build 1128 i nie miałem domyślnie YouTube w HD Station. Pobrałem ze strony qnap'a pliczek YouTube_1.0.1_x86.qpkg i ręcznie zainstalowałem - poszło :)
Też znalazłem youtube jako oddzielną paczkę z tym, że w opisie stoi, że to tylko dla modeli x70 :D Inna ciekawostka jest taka, że ze względu małego crasha wróciłem do wersji 4.0.3 i po instalacji na czystko okazało się, że również nie mam opcji instalacji youtube.
ts-469 proTS-469 Pro firmware 4.1.0 build 1128 beta 2 smb gołąb posso trovarlo grazieTS-469 Pro Firmware 4.1.0 Build 1128 where to download it pleaseI'm finding various broblemi with version 4.1.0 build1112smb someone can help me to find the version of the next sequence. thanks
