Download [Beta 2] QTS 4.3.3.0127 Build 0320 | ARM & x86 !~ TS-X28/TAS-X68
Silas Mariusz
rm -rf /
Help us, GOD!
10 234
31
2 401
153
39
forum.qnap.net.pl
[Bug fixes]
- Fixed a vulnerability in a configuration file that could be exploited to compromise the security of sensitive data. (CVE-2017-5227)
- Fixed an Apache HTTP Server vulnerability that could be exploited to deny requests to a server. (CVE-2016-8740)
- Fixed a stack overflow vulnerability that could be exploited to gain control of the EIP register.
- Fixed a SQL injection vulnerability that could be exploited to execute arbitrary SQL commands
- Fixed a command injection vulnerability in transcoding that could be exploited to execute unauthorized commands.
- Fixed a heap overflow vulnerability.
- Fixed a cross-site scripting vulnerability that could be exploited to inject arbitrary JavaScript commands.
- Fixed 2 stack overflow vulnerabilities that could be exploited to cause segmentation faults and gain control of the EIP register.
- Fixed a command injection vulnerability that could be exploited to execute unauthorized commands. (CVE-2017-6361)
- Fixed a command injection vulnerability that could be exploited to gain administrator privileges and unrestricted access to sensitive data. (CVE-2017-6360)
- Fixed a command injection vulnerability that could be exploited to gain the administrator privileges and execute unauthorized commands. (CVE-2017-6359)
- Fixed an access control vulnerability that would incorrectly restrict authorized user access to resources.
- Fixed 2 stack overflow vulnerabilities.
- Fixed an issue where users could not simultaneously perform multiple file copying tasks in a NAS shared folder mounted on a Mac via AFP.
- Fixed an issue where Media Library could not create thumbnails for certain JPEG files.
- Fixed an issue where users could not import the .ovpn configuration file created by QVPN to an OpenVPN client program in certain situations.
- Fixed an issue where a USB Wi-Fi dongle could not be detected again after the dongle was disconnected and reconnected to the NAS.
- Fixed an issue where the IP addresses of adapters in Network & Virtual Switch would be displayed incorrectly after QRM+ Beta 0.9.0 was installed.
- Fixed an issue where the CPU usage would spike regularly every 30 seconds when users logged in to the NAS via the web console.
- Fixed an issue where the network mode of a virtual switch created in Container Station would change from NAT to Bridge after a physical adapter was added to the virtual switch.
- Fixed an issue where Backup Station would not display available destination folders on a remote NAS where the log-in password contained the characters %^&*() when users created a RTRR FTP job.
- Fixed an issue where Storage Manager could not correctly report the health status of certain disks that had I/O errors.
- Fixed an issue where folders named in Korean or Japanese would not be arranged correctly in File Station when sorted by their names.
- Fixed an issue where Dashboard would not display the names of static volumes in error messages.
- Fixed multiple network vulnerabilities in QTS.
[Download]
https://download.qnap.com/Storage/HS-210TurboNAS/HS-210_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/HS-251/HS-251_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/IS-400/IS-400_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/SS-EC1279U-SAS-RP/SS-1279U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/SS-EC1879U-SAS-RP/SS-1879U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/SS-EC2479U-SAS-RP/SS-2479U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-1079ProTurboNAS/TS-1079_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-112TurboNAS/TS-112_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-119TurboNAS/TS-119_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-120TurboNAS/TS-120_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-121TurboNAS/TS-121_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-1269U-RP/TS-1269U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-1270U-RP/TS-1270U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-1279U-RP/TS-1279U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/T...S-131P_231P_431P_X31+_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-1679U-RP/TS-1679U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-212TurboNAS/TS-212_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-219TurboNAS/TS-219_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-220TurboNAS/TS-220_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-221TurboNAS/TS-221_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-269ProTurboNAS/TS-269_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-412TurboNAS/TS-412_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-412UTurboNAS/TS-412U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-419PTurboNAS/TS-419P_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-419UTurboNAS/TS-419U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-420TurboNAS/TS-420_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-420UTurboNAS/TS-420U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-421TurboNAS/TS-421_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-421UTurboNAS/TS-421U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-469ProTurboNAS/TS-469_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-469U-RP/TS-469U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-470ProTurboNAS/TS-470_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-470U-RP/TS-470U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-531P/TS-531P_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-563/TS-563_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-569ProTurboNAS/TS-569_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-669ProTurboNAS/TS-669_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-670ProTurboNAS/TS-670_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-869ProTurboNAS/TS-869_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-869U-RP/TS-869U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-870ProTurboNAS/TS-870_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-870U-RP/TS-870U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-879ProTurboNAS/TS-879_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-879U-RPTurboNAS/TS-879U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X31/TS-X31_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X31U/TS-X31U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-531X_831X/TS-X31X_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X31XU/TS-X31XU_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X35/TS-X35_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X51/TS-X51_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X51A/TS-X51A_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X51U/TS-X51U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X53/TS-X53_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X53A/TS-X53A_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X53B/TS-X53B_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X53S/TS-X53S_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X53U/TS-X53U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X63U/TS-X63U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X80/TS-X80_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X80U/TS-X80U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X82/TS-X82_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X82S/TS-X82S_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X85U/TS-X85U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X89U/TS-X89U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TVS-X63/TVS-X63_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TVS-X71/TVS-X71_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TVS-X71U/TVS-X71U_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TVS-X73/TVS-X73_20170320-4.3.3.0127.zip
https://download.qnap.com/Storage/TS-X85/TS-X85_20170320-4.3.3.0127.zip
U mnie przestały działać uprawnienia dawane grupom. Poszczególni użytkownicy przypisywali się do folderów i wszystko działało, a grupy niby się przypisywały ale nie miały dostępu do folderów. Cofka do poprzedniej wersji nie naprawiła sytuacji. Format na poprzedniej wersji, załatwił sprawę. Nie wiem czy to zbieg okoliczności czy coś się wysypało u mnie. W każdym razie TS-451 obecnie nie znajduje automatycznie aktualizacji do [Beta 2] QTS 4.3.3.0127 Build 0320 (betą mam włączoną). Można zainstalować tylko z palca pobrane z linków powyżej.
mi rtorrent zaczął działać jak zrobiłem downgreade z w/w wersji do tej co na oficjalnej stronie qnapa jest (TS-X53A_20170216-4.3.3.0095)
Nie mam pewności czy to jest spowodowane updatem, ale nie działa mi samba ;(
Nie mam pewności, bo wcześniej samba była uruchomiona, ale jej nie używałem, więc nie wiem czy to od początku tak nie było.
Samba włączona, czyli usługa plików dla sieci Microsoft, nazwa skonfigurowana, a nawet stacja jest widoczna w otoczeniu sieciowym, ale po dwukliku nie da rady wejść. Nie pyta o hasło, tylko od razu rzuca, że serwer niedostępny. Próbowałem po nazwie i po IP.
Po zeskanowaniu portów nie widać, że porty 139 i 445 są otwarte.
Włączenie/wyłączenie samby nie daje efektu. Tak samo jak restart QNAP-a czy kompa (Windows 10).
Help ;)
Help ;)
U mnie na TS-251 zarówno Samba (każda dostępna wersja beta) jak i NFS działają bez zarzutu (z NFS był jakiś problem na poprzedniej wersji, ale na obecnej problemy się skończyły)
No a w logach połączeń co masz?
W ogóle czytasz coś takiego jak logi?
Właśnie w ogóle nie ma logów połączeń. Tak jakby usługa w ogóle nie chodziła. Albo coś blokuje porty, ale nic tu nie mam zablokowanego (poza tym netstat z serwera nie pokazuje otwartych portów dla samby).
Robiłem restart samby i nie zgłasza w shellu żadnych problemów:
[~] # /etc/init.d/smb.sh restart
Restarting SMB services:
Shutting down SMB services: smbd smbd-notifyd cleanupd nmbd.
Shutting down winbindd services: winbindd.
locks path was set to /share/CACHEDEV1_DATA/.locks
Starting winbindd services: Starting SMB services:.
done.
qnap 112p na tej wersji firmware podobnie jak na 4.3.3.0095 dioda usb miga jak szalona a do portów nic nie jest wpięte.
z ciekawości zainstaluje ...
smb działa poprawnie u mnie
