ChangeLog rtorrent-Pro 0.9.6-0417 RC1
Silas Mariusz
rm -rf /
Help us, GOD!
10 236
31
2 404
153
39
forum.qnap.net.pl
RC1 BUILD
Security fixed
- [CRITICAL] Fixed security issue with RPC2 accessible without any authentification
Major changes
x Filebot incl. - 6 months for FREE, after 6 months, full 7 days trial renewed every week
- Do not require manual installation of FileBot & Java 8 in the system anymore (Recommend: remove these apps if not using for other purpose)
(it is using built-in packages which do not conflict to system dependencies)
x MediaLibrary internal queue manager to handle scanning tasks in background (prevents UI hanging/freezing)
x MediaLibrary automatically scan every 4am whole content of complete or downloads directories and searching for Movies, TV Shows, Music...
(depends if 'move to complete' is enabled in autotools UI settings otherwise use downloads dir instead complete for media source)
x Fixed IP Blocklist downloader
x Increased overall download and upload performance
x Improved Network Boost Tweak (this is recommended when: a] your ISP is offering DL speed more than 250Mbit; b] when reducing disk seeking while flushing large chunks)
- IMPORTANT NOTE: in both it is higly advised to have 4GB of RAM at least. Network Boost does not do nothing when dont have enough RAM to map download chunks.
- PRACTICE: Memory Limit settings is 4GB for 1Gigabit link.
- HELP: Memory Limit is not Memory Usage/Exclusive Memory Reservation). No. It define only how much of RAM rtorrent can use at time.
Minor changes
x Fixed download finish events notifications
x Removed ports limitation ~65535
x Faster connecting to DHT network (for Public torrent trackers)
x Fixed incorrectly duplicating data using copy method instead hardlink by Filebot when doing duplication on same disk volume
x rtorrent-Pro price is now 15 EUR
Reakcje: Kreonium
Good to have some of those topics addressed and hopefully, taken care about.
Maybe you like to give me your PM or any way of direct communication, i might have some more findings that i learned, wont get handled well, if those are communicated public.
Regards
A co jeśli mam licencję?
Czyli nie przeszkadza i nie pogryzą się jeśli się zostawi?
Da się zmienić częstotliwość/czas skanowania?
Pozdrawiam i przepraszam, jeśli te pytania wydają się głupie... :D
i dont understand why do i need to wait till 4 am the next day to update my Library and I like the button where you manually update the media from the setting sometimes I download to the rdownload folder using jdownload and manually update, how can I do that now?
Reakcje: Kreonium
This is what you should expect in RC2 release:
  1. rpc2
