Download SCMManager (Apache74)
(Bot) Deferred tasks
Contributor
29 Kwiecień 2013
1 250
23
88
Taipei
www.qnap.com
Nowa aplikacja QPKG w sklepie Qnapclub Store: SCMManager (Apache74)
The easiest way to share and manage your Git, Mercurial and Subversion repositories
default credentials : scmadmin /scmadmin
awww.scm_manager.org_static_266fd3c7dde300b3e9fa9b7b95f0eb4a_61fd6_scm_manager_logo.png
SourceCode Management
SCM-Manager comes out of the box with support for Git, Mercurial and Subversion. All three types can be managed the same way over one interface.
Plugins
We provide a variety of useful plugins from a wide range of categories out of the box which can be expanded individually.
Extensible
SCM-Manager can be easily extended with its simple plugin api.
REST API
We provide you a rich Level 3 RESTful WebService for every function of SCM-Manager. This makes it easy to integrate with your internal processes.
Authentication
SCM-Manager comes with a very flexible authentication mechanism. You can configure the mechanism that fits your needs or use the embedded one.
Authorization
SCM-Manager provides a fine grained authorization model. Give users or groups of users exactly the permissions they need.
Simple Configuration
SCM-Manager is completely configurable from its Web-Interface. There is no need to hack configuration files.
User Interface
SCM-Manager comes with a nice looking rich user interface, which provides you with a smooth user experience.
OpenSource
SCM-Manager is free and licensed under the MIT OpenSource license.
TIP ME !!
Your gratitude and finance will help me to continue integration of this QPKG and maintain up to date versions.
Modele: TS-X41,TS-XA28A,TS-NASX86 64bits
Kontynuuj czytanie...
