Bot
Management
29 Kwiecień 2013
4 853
38
265
Taipei
www.qnap.com
Nowa aplikacja QPKG w sklepie Qnapclub Store: Act
Run your GitHub Actions locally
https://github.com/nektos/act
Run your GitHub Actions locally! Why would you want to do this? Two reasons:
Fast Feedback - Rather than having to commit/push every time you want to test out the changes you are making to your .github/workflows/ files (or for any changes to embedded GitHub actions), you can use act to run the actions locally. The environment variables and filesystem are all configured to match what GitHub provides.
Local Task Runner - I love make. However, I also hate repeating myself. With act, you can use the GitHub Actions defined in your .github/workflows/ to replace your Makefile!
How Does It Work?
When you run act it reads in your GitHub Actions from .github/workflows/ and determines the set of actions that need to be run. It uses the Docker API to either pull or build the necessary images, as defined in your workflow files and finally determines the execution path based on the dependencies that were defined. Once it has the execution path, it then uses the Docker API to run containers for each action based on the images prepared earlier. The environment variables and filesystem are all configured to match what GitHub
provides.
TIP ME !!
Your gratitude and finance will help me to continue integration of this QPKG and maintain up to date versions.
Modele: TS-NASX86 64bits,TS-NASX86
Kontynuuj czytanie...
