[Beta] v3.2.0 Build0429 for TS-109/209/409/409U
Silas Mariusz
rm -rf /
Help us, GOD!
10 331
34
2 657
153
40
forum.qnap.net.pl
[Before Getting Started]
- It's highly suggested that you should back up all the data before applying this update.
- If you found the UI is incomplete/incorrect, please try to clear the browser's cache first and then refresh current page.
[Version & Build]
v3.2.0 Build0429
[Checksum]
TS-109: 132107606
TS-209: 3936037612
TS-409: 2139999826
TS-409U: 4004228692
[What's New?]
-Web File Manager 2
* Brand new user interface with best use experience
* Supports file compression (Download all files as a zip file)
* Supports file searching
* Supports drag-n-drop: moving file & folder within NAS
* Multiple files uploading /downloading
* Upload: up to 128 files at a time
* Download: auto-compress selected files into one zip file
- TwonkyMedia Server 5.1.4
- Apple Time Machine support
- Support 1TB WD EARS hard drive series (4k sector hard drive)
Note: Must upgrade to NAS v3.2.0 firmware, backup the data to another location, and then re-initialize the HDDs to adopt the WD Advanced Format Technology.
Please refer to http://wiki.qnap.com/wiki/Complete_Reinitialization
[Enhancements]
- Web Administration supports fuzzy search
- Daylight Saving Time Enhancement
- Buzzer control
- Upgrade iTunes Server
- Upgrade Samba to 3.3.9
[Major Bug Fixes]
- Fixed Y-cam recording issue if the camera has firmware 2.1.0 or beyond
- Fixed FCS-1030 camera recording issue
- Fixed changing administration port will cause remote access with port forwarding to fail
- Fixed failed Remote Replication in some circumstances
- Fixed UI display error (Linear Disk Volume) when creating new shares on a RAID 1 volume
- Fixed Mac permission issue
- Fixed Google Chrome & Firefox cannot download QPKGs on the Get QPKG page
[Known Issues]
- Enabling UPnP (TwonkyMedia) will cause HDD standby/sleep to fail
- Twonky Media Server self-restarts on some media files
- Twonky Media Server is unable to display some MP4 files
- For first-time installation, can only use 'Settings' -> 'Run Quick Configuration Wizard' in QNAP finder to setup NAS
[Downloads]
TS-109/ 109II/ 109 Pro/ 109 Pro II
http://gator368.hostgator.com/~qnap/Sto ... ld0429.zip
TS-209/ 209II/ 209 Pro/ 209 Pro II
TS-409/ 409 Pro
TS-409U
Re: TS-x09 Pro/Std Oficjalny FW (Version 3.2.0 Build 0429)
Mam pytanie, bo może gdzieś nie doczytałem.
To dzial beta, a tytuł wątku "oficjalny"
Na stronie qnapa nic nie ma.
Jak to jest z tą wersją?
Pzdr
  1. ts-409u
