UWAGA! W nowym firmware jest nowy kernel i nowe sterowniki NTFS, które powodują niepoprawną pracę zewnętrznych dysków w formacie NTFS/FAT. Użytkownicy korzystający z zewnętrznych dysków nie powinni instalować tego firmwaru.
[Before Getting Started]
- It's highly suggested that you should back up all the data before applying this update.
- If you found the UI is incomplete/incorrect, please try to clear the browser's cache first and then refresh current page.
- The differences between Build0512 and Build0607 are marked in RED
[Notice]
After doing some internel evaluations, we have decided to remove NFSv4 support from the firmware, and won't include it in the official release.
[Version & Build]
v3.3.0 Build0607
[What's New?]
- Multimedia Station 2 with iPhone/iPod Touch (QMobile) support
- Support HFS+ file system read & write on external drives
- ISO Mount (for both Web File Manager & NAS Web Administration)
- Virtual Host
- Zend Optimizer
- Buzzer control
- Surveillance Station supports the following new IP cameras:
Axis: M1011-W, M-1011, M-1031-W, 206, 206W, 207W
Vivotek: IP7330, IP7142, IP7135, FD7131
D-Link: DCS 2121, 5220 A2
Linksys: WVC54GCA, WVC54GC
- Firmware Live Update
- System Migration
[Enhancements]
- Time Machine backup management
- Enhanced quota management
- Option for enabling SFTP
- Enhanced Resource Monitor
- QMobile support in Bonjour
- Support Windows file attributes
- In Windows Networking, provide more options such as login styles of domain users and NTLMv2 authentication
- Upgraded Samba to 3.5.2
- Upgraded Proftpd to 1.3.2e
- Upgraded iTunes Server (Mt-daap:v0.2.4.1)
- New modules support on php: dba, dbase, shmop, wddx, zip, xmlrpc
- Microsoft Networking Advanced options
* Login style: DOMAIN\USERNAME instead of DOMAIN+USERNAME
* Automatically register in DNS
- Add "refresh" button to immediately get domain user/group
- Support wins in DHCP server
- Add publish date for latest news (RSS reader)
- Upgraded Linux kernel to 2.6.33.2
- Upgraded Netatalk to 2.1 (AFP 3.2)
- UpgradeD mDNSResponder(Bonjour) to 214.3
- Upgraded TwonkyMedia server to 5.1.5
[Major Bug Fixes]
- [System Administration] On TS-859U, the status LED remains lit even after entering HDD standby mode
- [System Administration] The IP addresses were not correctly displayed in the logs in some situations
- [System Administration] Notification was not sent after NAS abnormal shutdown
- [System Administration] DST errors in some regions
- [Disk Management] Thin-provisioning created LUN over 2TB cannot be renamed
- [Disk Management] HDD S.M.A.R.T. test errors on some hard drives
- [Backup] Synchronized backup to external drives if it contains some special symbols
- [Network Services] login error if FTP with SSL/TLS (Explicit) is enabled
- [Network Services] The "Re-launch process [proftpd]" error if too many shares exist
- [Network Services] Display error after the change of file name encoding
- [Network Services] Did not advertise WINS in DHCP response
- [Surveillance Station] Codec installation failure on 64-bit Windows
- [Surveillance Station] Please install the following tools on your PC if VIVOTEK and its OEM cameras do not function properly.
http://files.qnap.com/download/Storage/ ... p1_x86.zip
http://files.qnap.com/download//Storage ... ,54300.zip
- [Time Machine] The quota setting in Time Machine cannot exceed 4TB
- [UPnP Media Server]Twonky Media Server self-restarts on some media files
- [UPnP Media Server] Twonky Media Server is unable to display some MP4 files
- Performance decrease 10% after network re-connect
- [iSCSI] Fail to create an iSCSI LUN which is larger than 20TB.
- [iSCSI] There is no log while start/stop the iSCSI service.
- [iSCSI] Wrong IP display in iSCSI online user log when the network portal is IPV6.
- [iSCSI] iSCSI LUN could not be attached successfully sometimes.
- [AFP] Fixed AFP connection issue when AppleDB is broken (recover DB automatically)
[Known Issues]
- (Surveillence Station) Y-CAM Generic V2 will be disconnected if selecting channel in Live View page.
- The auto-generated playlists, like "Last Played" and "Most Played" are not working in TwonkyServer 5.1.5
[Download]
TS-239
Mirror 1: United States
TS-239 Pro II
TS-259
TS-439
TS-439U
TS-439 Pro II
TS-459
TS-459U
TS-509
TS-559
TS-639
TS-659
TS-809
TS-809U
TS-859
TS-859U
SS-439
SS-839
[Notice]
[Version & Build]
v3.3.0 Build0607
[What's New?]
- Virtual Host
- Zend Optimizer
- Buzzer control
- System Migration
[Enhancements]
[Major Bug Fixes]
[Known Issues]
[Download]
TS-239
TS-239 Pro II
TS-259
TS-439
TS-439U
TS-439 Pro II
TS-459
TS-459U
TS-509
TS-559
TS-639
TS-659
TS-809
TS-809U
TS-859
TS-859U
SS-439
SS-839
