[Before Getting Started]
- It's highly suggested that you should back up all the data before applying this update.
- If you found the UI is incomplete/incorrect, please try to clear the browser's cache first and then refresh current page.
[Version & Build]
v3.3.0 Build0903
[Checksum]
TS-109: 386067308
TS-209: 2428124319
TS-409: 2475889477
TS-409U: 2529620872
[What's New?]
- MSV2 support (exclude video transcoding)
- Option for enabling SFTP
[Enhancements]
- Time Machine backup management
- QMobile support in Bonjour
- Upgraded Samba to 3.5.2
- Upgraded Netatalk to 2.1
* Upgrade libdb to 4.6
- Web Administration page layout can be remembered
- Add surveillance station in the system service screen
[Major Bug Fixes]
- Fixed occasional disconnection issue when downloading files through Web File Manager
- Fixed the file transfer can't be resumed in FTP after the interruption of upload/download task
- Fixed the incorrect "Directory to backup" in [Back up to External Drive] if the length of folder name was over 228 characters
[Known Issues]
- Enabling UPnP (TwonkyMedia) will cause HDD standby/sleep to fail
- Twonky Media Server self-restarts on some media files
- Twonky Media Server is unable to display some MP4 files
- For first-time installation, can only use 'Settings' -> 'Run Quick Configuration Wizard' in QNAP finder to setup NAS
[Downloads]
TS-109
US Link: http://resources.qnap.com/~qnap/Storage ... ld0903.zip
TW Link: http://files.qnap.com/download/Storage/ ... ld0903.zip
TS-209
TS-409
TS-409U
[Version & Build]
v3.3.0 Build0903
[Checksum]
TS-109: 386067308
TS-209: 2428124319
TS-409: 2475889477
TS-409U: 2529620872
[What's New?]
[Enhancements]
[Major Bug Fixes]
[Known Issues]
[Downloads]
TS-109
TS-209
TS-409
TS-409U
