[~] # fdisk -l
Disk /dev/mtdblock0: 0 MB, 524288 bytes
255 heads, 63 sectors/track, 0 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk /dev/mtdblock0 doesn't contain a valid partition table
Disk /dev/mtdblock1: 2 MB, 2097152 bytes
Disk /dev/mtdblock1 doesn't contain a valid partition table
Disk /dev/mtdblock2: 9 MB, 9437184 bytes
255 heads, 63 sectors/track, 1 cylinders
Disk /dev/mtdblock2 doesn't contain a valid partition table
Disk /dev/mtdblock3: 3 MB, 3145728 bytes
Disk /dev/mtdblock3 doesn't contain a valid partition table
Disk /dev/mtdblock4: 0 MB, 262144 bytes
Disk /dev/mtdblock4 doesn't contain a valid partition table
Disk /dev/mtdblock5: 1 MB, 1310720 bytes
Disk /dev/mtdblock5 doesn't contain a valid partition table
You must set cylinders.
You can do this from the extra functions menu.
Disk /dev/sda: 0 MB, 0 bytes
Device Boot Start End Blocks Id System
/dev/sda1 1 267350 2147483647+ ee EFI GPT
Partition 1 has different physical/logical beginnings (non-Linux?):
phys=(0, 0, 1) logical=(0, 0, 2)
Partition 1 has different physical/logical endings:
phys=(1023, 254, 63) logical=(267349, 89, 4)
Disk /dev/sda4: 469 MB, 469893120 bytes
2 heads, 4 sectors/track, 114720 cylinders
Units = cylinders of 8 * 512 = 4096 bytes
Disk /dev/sda4 doesn't contain a valid partition table
Disk /dev/sdb: 0 MB, 0 bytes
/dev/sdb1 1 267350 2147483647+ ee EFI GPT
Disk /dev/md9: 542 MB, 542834688 bytes
2 heads, 4 sectors/track, 132528 cylinders
Disk /dev/md9 doesn't contain a valid partition table
Disk /dev/md2: 542 MB, 542851072 bytes
2 heads, 4 sectors/track, 132532 cylinders
Disk /dev/md2 doesn't contain a valid partition table
Disk /dev/md0: 0 MB, 0 bytes
2 heads, 4 sectors/track, 0 cylinders
Disk /dev/md0 doesn't contain a valid partition table
[~] # [~] # fdisk -l
-sh: [~]: command not found
[~] # Disk /dev/mtdblock0: 0 MB, 524288 bytes
-sh: Disk: command not found
[~] # 255 heads, 63 sectors/track, 0 cylinders
-sh: 255: command not found
[~] # Units = cylinders of 16065 * 512 = 8225280 bytes
-sh: Units: command not found
[~] # Disk /dev/mtdblock0 doesn't contain a valid partition table
[~] # Disk /dev/mtdblock2: 9 MB, 9437184 bytes
[~] # 255 heads, 63 sectors/track, 1 cylinders
[~] # Disk /dev/mtdblock2 doesn't contain a valid partition table
[~] # Disk /dev/mtdblock4: 0 MB, 262144 bytes
[~] # Disk /dev/mtdblock4 doesn't contain a valid partition table
[~] # You must set cylinders.
-sh: You: command not found
[~] # You can do this from the extra functions menu.
[~] # Disk /dev/sda: 0 MB, 0 bytes
[~] # Device Boot Start End Blocks Id System
-sh: Device: command not found
[~] # /dev/sda1 1 267350 2147483647+ ee EFI GPT
-sh: /dev/sda1: Permission denied
[~] # Partition 1 has different physical/logical beginnings (non-Linux?):
-sh: syntax error near unexpected token `('
[~] # phys=(0, 0, 1) logical=(0, 0, 2)
[~] # Partition 1 has different physical/logical endings:
-sh: Partition: command not found
[~] # phys=(1023, 254, 63) logical=(267349, 89, 4)
[~] # Disk /dev/sda4: 469 MB, 469893120 bytes
[~] # 2 heads, 4 sectors/track, 114720 cylinders
-sh: 2: command not found
[~] # Units = cylinders of 8 * 512 = 4096 bytes
[~] # Disk /dev/sda4 doesn't contain a valid partition table
[~] # Disk /dev/md2: 542 MB, 542851072 bytes
[~] # 2 heads, 4 sectors/track, 132532 cylinders
[~] # Disk /dev/md2 doesn't contain a valid partition table
