Bot
Management
29 Kwiecień 2013
4 845
37
265
Taipei
www.qnap.com
Nowa aplikacja QPKG w sklepie Qnapclub Store: hub
A command-line tool that makes git easier to use with GitHub
hub is an extension to command-line git that helps you do everyday GitHub tasks without ever leaving the terminal.
Whether you are beginner or an experienced contributor to open-source, hub makes it easier to fetch repositories, navigate project pages, fork repos and even submit pull requests, all from the command-line.
Scripting your workflows is much easier now that you can list and create issues, pull requests, and GitHub releases.
As someone who loves automation
As an open-source maintainer
Maintaining a project is easier when you can easily fetch from other forks, review pull requests and cherry-pick URLs. You can even create a new repo for your next thing.
Using GitHub for work
Save time at work by opening pull requests for code reviews and pushing to multiple remotes at once. Even GitHub Enterprise is supported.
Your gratitude and finance will help me to continue integration of this QPKG and maintain up to date versions.
Modele: TS-ARM-X19,TS-X41,TS-NASX86 64bits,TS-X28A,TS-X31,TS-NASX86
Kontynuuj czytanie...
