FAQ Pair Autobrr with Rtorrent-Pro
Silas Mariusz
rm -rf /
Help us, GOD!
10 396
36
2 908
153
40
forum.qnap.net.pl
  1. First you have to install Autobrr.
    To do this, you have to follow quick manual from here: https://forum.qnap.net.pl/threads/app-center-dodatkowe-repozytoria-z-aplikacjami-dla-qnap.39855/
  2. Once you add new repository to QNAP NAS App Center - MyQNAP.org you are ready to install Autobrr. Let's do this.
  3. Okay, hit mouse left-click button on Autobrr to open the app
  4. Follow Autobrr configuration, register new user and login again to autobrr.
  5. On the top bar of the app click "SETTING" menu item.
  6. Now from the left sidebar of main settings windows sellect Clients tab.
  7. In a middle of that windows you should see "+ New client" button. Push it.
  8. Fancy sidebar shoud now slide from right of the screen.
    There is not much to configure but make sure to select Rtorrent and on the TOP fill name of your download client. Let it be Rtorrent.
  9. Scroll your mouse down and you should see field to enter download client host name:
    And thats a tricky now little bit.
    I'm not sure you wanna know how Rtorrent-Pro was designed, but if the client app is running on same host where Rtorrent-Pro is - which means localhost, then authorization is not required.
    So its absolutely enough to type: http://localhost:6009/RPC2
  10. After sometime this app started to download my filter:
  11. This is worst downloading app I evern seen. It works with with Rtorrent-Pro but I do not recommend it absolutelly.
Reakcje: Kreonium
  1. autodl-irssi
  2. autobrr
  3. rtorrent-pro
  4. RPC2
  5. "autobrr" "rtorrent" "rpc2"
  6. https://forum.qnap.net.pl/threads/pair-autobrr-with-rtorrent-pro.40074/
  7. rtorrent
  8. qts 4.2.6 no login
  9. repozytoria
