First post here, so apologies if this is the wrong place—also, I don’t speak Polish.
I think I’m having a seeding issue.
It seems like it’s seeding, but it actually isn’t, and the ones that used to seed successfully no longer does.
(downloading is fine)
I’m not sure if there’s a specific port I need to open, but at the same time, it says ok in the photo
(see photo).
I don’t really know where to start troubleshooting this.
For context, I have a fiber connection with 1 GB upload and download speeds.
The network is managed using Ubiquiti equipment, specifically a Dream Machine Pro, which controls all ports, etc. Here’s how it’s set up:
The router from my ISP is connected directly to the Dream Machine via one cable. Some ports are open, and supposedly there’s no firewall enabled.
Looking forward if someone here can give me a hand to sort this?
(see photo).
