SS-439 Pro Official FW (Version 3.1.1 Build 0812)
Silas Mariusz
rm -rf /
Help us, GOD!
10 331
34
2 657
153
40
forum.qnap.net.pl
TS-x39/50/809/809U | SS-x39 Official Firmware v3.1.1 Build0812
[Przed rozpoczęciem]
- Zalecane jest zarchiwizowanie danych znajdujących się na NAS'ie, przed rozpoczęciem aktualizacji firmware.
- Jeśli interfejs załaduję się niekompletny, wyczyść cache przeglądarki i odśwież stronę.
[Wersja i Wydanie]
v3.1.1 Build0812
[Sumy kontrolne]
TS-239: 146489026
TS-439: 2973915901
TS-439U: 2162584290
TS-509: 2723624544
TS-639: 1084152220
TS-809: 656799858
TS-809U: 2277487489
SS-439: 3723487489
SS-839: 2277487489
[Rozszerzenia]
- Quick Search (user/group/share) supports fuzzy search
- Smart Fan based on system, HDD, & CPU temperatures
- Windows AD enhancement: now supports 100,000 domain users and groups with faster response time.
- Return to the login page after being inactive for 1 hour
[Poprawki]
- couldnot switch between normal login and SSL login
- domain user could not change password
- If one touch copy function failed, then the copy to external device function also failed
- SMTP Server,Sender and User Name could not accept "+"
- Web File Manager could not upload files to share in VDD share folders
- VDD share was not removed when formatting the VDD
- AD users did not have access right in FTP service
- When there are more than 100,000 AD users, quota could not be applied successfully
- If a user name contains '(' or ')', the access right can't be set in share folders
- When the administration port has been changed, remote access with port forwading will fail
- Created a private share with '&' character in create user function, the real folder would not be created
- Web File Manager security issue
- DHCP server could not be enabled on bonding type
- Edit user quota, the page would go to login page
- Persistent "Loading now, please wait" message in the notification page in some conditions
- "&" in the share folder or user names causing logout
- Quota did not work for domain users
[Pobierz]
SS-439
Mirror 1: United States
Mirror 2: Europe
Mirror 3: Taiwan
Mirror 4: Germany
