[Przed rozpoczęciem]
- Zalecane jest zarchiwizowanie danych znajdujących się na NAS'ie, przed rozpoczęciem aktualizacji firmware.
- Jeśli interfejs załaduję się niekompletny, wyczyść cache przeglądarki i odśwież stronę.
[Wersja i Wydanie]
v3.1.1 Build0815
[Sumy kontrolne]
TS-239: 1625055454
TS-439: 4282602702
TS-439U: 2583320945
TS-509: 1353232594
TS-639: 3496551090
TS-809: 1425461439
TS-809U: 3902057494
SS-439: 456394340
SS-839: 4052949254
[Rozszerzenia]
- Quick Search (user/group/share) supports fuzzy search
- Smart Fan based on system, HDD, & CPU temperatures
- Windows AD enhancement: now supports 100,000 domain users and groups with faster response time.
- Return to the login page after being inactive for 1 hour
[Poprawki]
- couldnot switch between normal login and SSL login
- domain user could not change password
- If one touch copy function failed, then the copy to external device function also failed
- SMTP Server,Sender and User Name could not accept "+"
- Web File Manager could not upload files to share in VDD share folders
- Access Right issue: When no user/user group is assigned to a new share folder, then all users have Read Only access.
- VDD share was not removed when formatting the VDD
- AD users did not have access right in FTP service
- When there are more than 100,000 AD users, quota could not be applied successfully
- If a user name contains '(' or ')', the access right can't be set in share folders
- When the administration port has been changed, remote access with port forwading will fail
- Created a private share with '&' character in create user function, the real folder would not be created
- Web File Manager security issue
- DHCP server could not be enabled on bonding type
- Edit user quota, the page would go to login page
- Persistent "Loading now, please wait" message in the notification page in some conditions
- "&" in the share folder or user names causing logout
- Quota did not work for domain users
[Pobierz]
SS-439
Mirror 1: United States
Mirror 2: Europe
Mirror 3: Taiwan
[Wersja i Wydanie]
v3.1.1 Build0815
[Sumy kontrolne]
TS-239: 1625055454
TS-439: 4282602702
TS-439U: 2583320945
TS-509: 1353232594
TS-639: 3496551090
TS-809: 1425461439
TS-809U: 3902057494
SS-439: 456394340
SS-839: 4052949254
[Rozszerzenia]
[Poprawki]
[Pobierz]
SS-439
Mirror 2: Europe
Mirror 3: Taiwan
