Pomoc Co jest grane TS-569 Pro
kolatek2
19 Lipiec 2012
42
Od kilku dni wywala mi w logach coś takiego:
92,"Error","2013-09-17","07:00:06","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/var/.application.conf], section = [PhotoStation], field = [Enable], value = [FALSE]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
91,"Error","2013-09-17","07:00:04","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/var/.application.conf], section = [MusicStation], field = [Enable], value = [FALSE]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
90,"Error","2013-09-17","07:00:04","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/var/.application.conf], section = [MultimediaStation], field = [USBSound], value = [TRUE]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
89,"Error","2013-09-17","06:59:37","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [BTDownload], field = [addonEnable], value = [TRUE]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
88,"Error","2013-09-17","06:59:37","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/def_share.info], section = [SHARE_DEF], field = [defVolMP], value = [/share/HDA_DATA]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
87,"Error","2013-09-17","06:59:36","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [TFTP Server], field = [Allowed mode], value = [0]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
86,"Error","2013-09-17","06:59:36","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [TFTP Server], field = [Log Subfolder], value = []) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
85,"Error","2013-09-17","06:59:36","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [TFTP Server], field = [Log Folder], value = [Public]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
84,"Error","2013-09-17","06:59:36","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [TFTP Server], field = [Root Subfolder], value = []) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
83,"Error","2013-09-17","06:59:36","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [TFTP Server], field = [Root Folder], value = [Public]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
82,"Error","2013-09-17","06:59:36","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [TFTP Server], field = [PORT], value = [69]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
81,"Error","2013-09-17","06:59:35","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [TFTP Server], field = [Enable], value = [FALSE]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
80,"Error","2013-09-17","06:58:23","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/.qos_config/users/admin/config], section = [common], field = [lastLoginVer], value = [4.0.2]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
79,"Error","2013-09-17","06:58:23","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/.qos_config/users/admin/config], section = [common], field = [lastLogin], value = [1379393902]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
78,"Error","2013-09-17","06:58:22","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/.qos_config/users/admin/config], section = [datetime], field = [login], value = [1379393902]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
77,"Error","2013-09-17","06:57:23","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/.qos_config/users/admin/config], section = [common], field = [lastLoginVer], value = [4.0.2]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
76,"Error","2013-09-17","06:57:23","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/.qos_config/users/admin/config], section = [common], field = [lastLogin], value = [1379393843]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
75,"Error","2013-09-17","06:57:23","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/.qos_config/users/admin/config], section = [datetime], field = [login], value = [1379393843]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
74,"Error","2013-09-17","06:56:00","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/.qos_config/users/admin/config], section = [common], field = [lastLoginVer], value = [4.0.2]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
73,"Error","2013-09-17","06:56:00","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/.qos_config/users/admin/config], section = [common], field = [lastLogin], value = [1379393760]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
72,"Error","2013-09-17","06:56:00","System","127.0.0.1","localhost","The system is unable to save your settings (file = [/etc/config/.qos_config/users/admin/config], section = [datetime], field = [login], value = [1379393760]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance."
Za groma jasnego nie wiem o co mu biega może ktoś ma jakiś pomysł w konfiguracji niczego nie zmieniałem się samo zrobiło :( (serwerek ma 3 GB RAM)
