Symptoms
Cause
This is a known issue, but it is not caused by Rtorrent itself. This may be because your volume is fragmented (the reverse process of disk defragmentation)
Resolution
There are two solution depends on what your needs.
Notice & Advise
Please always keep at least 20% free space on your disks.
Ref. links:
Rtorrent-Pro [x86_64] - Aktualizacje
Pomoc - Excessive HDD Activity on EXT 4 file system when downloading some torrents
- Excessive HDD Activity when downloading torrents
Cause
Resolution
- if your maximum download bandwidth is limited to 1Gbit/s you can simply disable "Preallocate files" from the rtorrent settings:
- however if your download ISP link is better than 1Gbit, eg. 2Gbit, 10Gbit or maybe more, then make sure to have enough space on disks
Notice & Advise
Ref. links:
