Perl:
#!/usr/bin/perl
print "content-type: text/html \n\n";
print "Hello, Perl!";
#!/usr/bin/perl
Lorem ipsum dolor sit amet, consectetur adipisicing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
#!/usr/local/bin/perl
use English;
use Carp;
use Getopt::Long;
sub Usage{
my $message = shift;
print STDERR $message, "\n" if $message;
print STDERR "\nUsage: $0 -d(ef) definition_file < source > newsource\n";
print STDERR <<'EOM';
-d(ef) filename : Specifies the definition file which is a set of pairs, each corresponding to a "replacement pattern", e.g.,
a A
b B
z Z
would replace all lower cases with upper cases
-h(elp) : display this message
EOM
exit(1);
if (! &GetOptions("help", "def=s") or
$opt_help) {
&Usage();
open(D, $opt_def) || die "can't open definition file:$opt_def\n";
while (<D>) {
($oldp, $newp) = split;
$dic{$oldp}=$newp;
close(D);
$oldStr = "";
$newStr ="";
while (<STDIN>) {
$oldStr = $_;
foreach $k (keys %dic) {
s/$k/$dic{$k}/g;
$newStr = $_;
if ($oldStr ne $newStr) {
print STDERR "\n";
print STDERR "old>>$oldStr";
print STDERR "new>>$newStr";
print;
$path = "/YOUR/PATH/TO/public_html/php_diary/data";
$filename = "122499.dat";
$x= -1;
if($file = fopen("$path/$filename", "r"))
while(!feof($file))
$therate = fgetss($file, 255);
$x++;
$count = $count + $therate;
fclose($file);
$average = ($count / $x);
print("Surfer Average Rating for 12/24/99: ");
printf("%.2f", $average);
print("<br>Total Surfer Votes: $x");
#!/bin/bash
# Declare variable choice and assign value 4
choice=4
# Print to stdout
echo "1. Bash"
echo "2. Scripting"
echo "3. Tutorial"
echo -n "Please choose a word [1,2 or 3]? "
# Loop while the variable choice is equal 4
# bash while loop
while [ $choice -eq 4 ]; do
# read user input
read choice
# bash nested if/else
if [ $choice -eq 1 ] ; then
echo "You have chosen word: Bash"
else
if [ $choice -eq 2 ] ; then
echo "You have chosen word: Scripting"
else
if [ $choice -eq 3 ] ; then
echo "You have chosen word: Tutorial"
else
echo "Please make a choice between 1-3 !"
echo "1. Bash"
echo "2. Scripting"
echo "3. Tutorial"
choice=4
fi
fi
fi
done
reprehenderit qui in ea voluptate velit esse quam nihil molestiae consequatur, vel illum qui dolorem eum fugiat quo voluptas nulla pariatur?
--- Połączono posty, 28 Maj 2013, Data oryginalnego postu: 27 Maj 2013 ---cell 1 cell 2 final cell
--- Połączono posty, 3 minut temu ---Silas Mariusz napisał: ↑
@QNAP tag test@QNAP tag test
http://main.makeuseoflimited.netdna-cdn.com/wp-content/uploads/2013/09/Internet-Explorer-11-Release-Preview-Windows-7-840x420.jpg
(Test automatycznej zamiany linku 1 - link do strony)…przynajmniej z punktu widzenia witryn, które przeglądarka wyświetla. Inżynierowie Microsoftu symbolicznie odcinają się od przeszłości, a co najważniejsze, gonią najnowsze standardy webowe. W rezultacie IE11 będzie nie tylko najlepszym IE w historii, ale po prostu nowoczesną i szybką przeglądarką www.
Internet Explorer 11 to jedna z nowości aktualizacji Windows 8.1, o której pisałem szerzej jakiś czas temu. Przeglądarka Microsoftu w tej wersji doczekała się naprawdę dużych zmian. Zaimplementowano w niej obsługę WebGL, funkcje prerenderowania oraz usprawniono współpracę z najnowszych technologiami webowymi. Już w wersji 10 Microsoft pokazał, że potrafi zrobić dziś dobrą przeglądarkę na miarę XXI wieku. Wersja 11 ma być tego niepodważalnym dowodem. Sęk w tym, że to już nie IE, co słusznie zauważył serwisNCZOnline.
Sekret tkwi w funkcji User Agent, czyli identyfikatorze przeglądarki, którym przedstawia ona się na stronach www. W ten sposób możliwe jest m.in. dostosowanie wyglądu witryny do możliwości danego programu czy chociażby uniknięcie wpadek związanych z brakiem kompatybilności. W ostatnich latach Internet Explorer był jednym z negatywnych bohaterów wśród osób pracujących nad stronach www. Wystarczy zajrzeć w pierwszy lepszy kaskadowy arkusz stylu, by zobaczyć selektory przygotowywane specjalnie z myślą o przeglądarce Microsoftu nie radzącej sobie ze standardowymi rozwiązaniami. Podobnie sytuacja wygląda z punktu widzenia programistów JavaScript.
http://antyweb.pl/internet-explorer-11-to-juz-nie-internet-explorer/
