Help Java not found
elperdigon
23
Hi
I´m trying to install jdownloader so 1st step is to get java
I´ve installed QJDK8 1.8.201 from repository, everything went fine apparently; but this is the message I get when I start the process to install -sh: java: command not found
Could anybody help me please?
Wersja oprogramowania Firmware: 4.3.6.0805 Build 20181227
Model serwera: QNAP TS-251A
not:
# -f java
should be:
# type -f java
or:
# command -v java
Thank you Silas, the other day I wrote -f java; that was the mistake
[~] # type -f java
java is /usr/local/jre/bin/java
In the end I succeed installing Jdownloader
Regards
  1. java command not found
