Czy to normalna sprawa, że co jakoś czas trzeba Qnapa zrestartować?.
Po restarcie wszystko działa poprawnie.
Czytałem, że problem z brakiem miejsca w pamięci ramdisk został już rozwiązany.
Podczas tego błędu większość informacji statystycznych nie działa (brak wykresów). Temperatura dysków, procesora i systemu wyświetla „—„, obroty wentylatorów z tego co pamiętam pokazują jakąś dziwną cyfrę. Menu bardzo wolno działa.
286 15:41:12 System 127.0.0.1 localhost The system is unable to save your settings (file = [/etc/config/qnapddns.conf], section = [QNAP DDNS Service], field = [Check External IP], value = [60]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance.
2011-07-07
285 15:41:12 System 127.0.0.1 localhost The system is unable to save your settings (file = [/var/qnapddns.conf], section = [QNAP DDNS Service], field = [Check External IP], value = [60]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance.
2011-07-07
284 15:40:45 System 127.0.0.1 localhost The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [iSCSI], field = [Uni String], value = [C67D7E]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance.
2011-07-07
283 15:40:45 System 127.0.0.1 localhost The system is unable to save your settings (file = [/etc/config/iscsi_trgt.conf], section = [iSCSIPortal], field = [targetIQNPrefix], value = [iqn.2004-04.com.qnap:ts-459u:iscsi.]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance.
2011-07-07
282 15:40:13 System 127.0.0.1 localhost The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [iSCSI], field = [Uni String], value = [C67D7E]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance.
2011-07-07
281 15:40:12 System 127.0.0.1 localhost The system is unable to save your settings (file = [/etc/config/iscsi_trgt.conf], section = [iSCSIPortal], field = [targetIQNPrefix], value = [iqn.2004-04.com.qnap:ts-459u:iscsi.]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance.
2011-07-07
280 15:32:54 System 127.0.0.1 localhost The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [DHCP Server], field = [End Range], value = [0.0.0.0]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance.
2011-07-07
279 15:32:54 System 127.0.0.1 localhost The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [DHCP Server], field = [Start Range], value = [0.0.0.0]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance.
2011-07-07
278 15:32:53 System 127.0.0.1 localhost The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [DHCP Server], field = [End Range], value = [0.0.0.0]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance.
2011-07-07
277 15:32:53 System 127.0.0.1 localhost The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [DHCP Server], field = [Start Range], value = [0.0.0.0]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance.
2011-07-07
276 15:32:52 System 127.0.0.1 localhost The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [DHCP Server], field = [End Range], value = [0.0.0.0]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance.
2011-07-07
275 15:32:52 System 127.0.0.1 localhost The system is unable to save your settings (file = [/etc/config/uLinux.conf], section = [DHCP Server], field = [Start Range], value = [0.0.0.0]) due to insufficient ramdisk space. If restarting the server does not solve the problem please contact support for further assistance.
