Download [Public Beta] QTS 4.2.1 Build 0201 | ARM & x86
Silas Mariusz
rm -rf /
Help us, GOD!
10 329
34
2 653
153
40
forum.qnap.net.pl
QTS4.2.1 Build 20160201
[Bug Fixes]
Fixed an issue where the Expand Capacity button will be enabled before changing any drive in Storage Manager.
Fixed an issue where an increasing amount of system RAM will be displayed while copying a large number of small files to the NAS.
Fixed an issue where the unallocated size will change after taking snapshots, copying some files, then rebooting the NAS.
Fixed an issue where the content of encrypted folders are not included in snapshots.
Fixed an issue where the system will fail to create a snapshot replica job to a remote NAS when there is a special character ')' in the password.
Fixed an issue where there is nothing shown in Background Tasks after Snapshot Replica is executed.
Fixed an issue where the system log shows "The file system is not clean...." when rebooting with various apps launched and RTRR in process.
Fixed an issue where the Media Library would occasionally show incomplete file information when changing the iTunes media folder to the NAS multimedia folder.
Fixed an issue where the WebDAV connection would fail after the HTTPS port is changed to 443.
Fixed an issue where the content page of songs would be cleared when uploading specific MP3 files.
Fixed an issue where the AFP connection would be interrupted when connecting through an encrypted folder.
Fixed an issue where files would be incompletely moved when repeatedly moving files between a shared folder and an external folder in File Station.
Fixed an issue where changing folder permissions would not take effect if changing the folder permissions from R/W to Read-only via Samba protocol.
Fixed an issue where the connection would fail during backing up a VM image to an external device.
Fixed an issue where an error message would appear when performing a RTRR task to backup files from local to remote and placing a folder to the source folder through SAMBA protocol.
Fixed an issue where the total number of music in the Media Library would be incorrect when adding .cue, .flac, and MP3 files into a folder.
Fixed an issue where the system would become unresponsive when uploading high-resolution pictures in Photo Station.
Fixed an issue where an error message would appear after creating a backup job and selecting specific folders in the source and destination folder where the selected folders have a prefix “share” in the folder name.
Fixed an issue where files in the root folder would become folders after cloning a Snapshot.
Fixed an issue where the system would show a warning message when linking to an OpenVPN server.
Fixed an issue where the log file would report incorrect information when swapping HDD locations in a NAS and removing the pool.
Fixed an issue where the pool expansion operation would fail.
Fixed an issue where the system would be unable to show a clear indication of the maximum volume size when creating volume with default settings.
Fixed an issue where the volume resize operation would fail if the file system is not clean.
Fixed an issue where background tasks would be stuck in a calculation step when uploading files to File Station using Firefox.
Fixed an issue where the “copy the link” option cannot be selected in download operations when sharing files with share links with the Android browser.
Fixed an issue where "Compression" in Backup settings would be unable to remain on the edit page when doing iSCSI Storage.
[Known issues]
A NAS may occasionally reboot twice and display a "The system was not shut down properly last time" in the system log.
iSCSI LUNs may be occasionally missing after 2-3 days in a environment with prolonged heavy I/O loading.
[Download]
http://download.qnap.com/Storage/HS-210TurboNAS/HS-210_20160201-4.2.1.zip
http://download.qnap.com/Storage/HS-251/HS-251_20160201-4.2.1.zip
http://download.qnap.com/Storage/IS-400/IS-400_20160201-4.2.1.zip
http://download.qnap.com/Storage/SS-439ProTurboNAS/SS-439_20160201-4.2.1.zip
http://download.qnap.com/Storage/SS-469/SS-469_20160201-4.2.1.zip
http://download.qnap.com/Storage/SS-839ProTurboNAS/SS-839_20160201-4.2.1.zip
http://download.qnap.com/Storage/SS-EC1279U-SAS-RP/SS-1279U_20160201-4.2.1.zip
http://download.qnap.com/Storage/SS-EC1879U-SAS-RP/SS-1879U_20160201-4.2.1.zip
http://download.qnap.com/Storage/SS-EC2479U-SAS-RP/SS-2479U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-1079ProTurboNAS/TS-1079_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-110TurboNAS/TS-110_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-112TurboNAS/TS-112_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-119TurboNAS/TS-119_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-120TurboNAS/TS-120_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-121TurboNAS/TS-121_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-1269U-RP/TS-1269U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-1270U-RP/TS-1270U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-1279U-RP/TS-1279U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-1679U-RP/TS-1679U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-210TurboNAS/TS-210_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-212TurboNAS/TS-212_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-219TurboNAS/TS-219_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-220TurboNAS/TS-220_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-221TurboNAS/TS-221_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-239HTurboNAS/TS-239H_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-239ProII+TurboNAS/TS-239PROII+_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-239ProIITurboNAS/TS-239PROII_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-239ProTurboNAS/TS-239_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-259ProTurboNAS/TS-259_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-269HTurboNAS/TS-269H_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-269ProTurboNAS/TS-269_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-410TurboNAS/TS-410_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-410UTurboNAS/TS-410U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-412TurboNAS/TS-412_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-412UTurboNAS/TS-412U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-419PTurboNAS/TS-419P_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-419UTurboNAS/TS-419U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-420TurboNAS/TS-420_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-420UTurboNAS/TS-420U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-421TurboNAS/TS-421_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-421UTurboNAS/TS-421U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-439ProII+TurboNAS/TS-439PROII+_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-439ProIITurboNAS/TS-439PROII_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-439ProTurboNAS/TS-439_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-439UTurboNAS/TS-439U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-459ProTurboNAS/TS-459_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-459UTurboNAS/TS-459U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-469ProTurboNAS/TS-469_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-469U-RP/TS-469U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-470ProTurboNAS/TS-470_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-470U-RP/TS-470U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-509ProTurboNAS/TS-509_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-559ProTurboNAS/TS-559_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-563/TS-563_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-569ProTurboNAS/TS-569_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-639ProTurboNAS/TS-639_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-659ProTurboNAS/TS-659_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-669ProTurboNAS/TS-669_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-670ProTurboNAS/TS-670_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-809ProTurboNAS/TS-809_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-809U-RP/TS-809U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-859ProTurboNAS/TS-859_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-859U-RPTurboNAS/TS-859U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-869ProTurboNAS/TS-869_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-869U-RP/TS-869U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-870ProTurboNAS/TS-870_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-870U-RP/TS-870U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-879ProTurboNAS/TS-879_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-879U-RPTurboNAS/TS-879U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X31/TS-X31_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X31+/TS-X31+_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X31P/TS-X31P_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X31U/TS-X31U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X51/TS-X51_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X51U/TS-X51U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X53/TS-X53_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X53A/TS-X53A_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X53S/TS-X53S_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X53U/TS-X53U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X63U/TS-X63U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X80/TS-X80_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X80U/TS-X80U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TS-X89U/TS-X89U_20160201-4.2.1.zip
http://download.qnap.com/Storage/TVS-X63/TVS-X63_20160201-4.2.1.zip
http://download.qnap.com/Storage/TVS-X71/TVS-X71_20160201-4.2.1.zip
http://download.qnap.com/Storage/TVS-X71U/TVS-X71U_20160201-4.2.1.zip
Po aktualizacji musiałem coś sprawdzić i dmseg zwraca mi coś takiego. Czy ktoś ma pomysł z czego to może wynikać?
[ 6059.498166] manaRequest.cgi[26610]: segfault at 58 ip 000000000805aab6 sp 00000000ffb7ac80 error 4 in manaRequest.cgi[8048000+24000]
[ 6074.659180] manaRequest.cgi[26843]: segfault at 58 ip 000000000805aab6 sp 00000000ffe42e30 error 4
[ 6074.663293] manaRequest.cgi[26846]: segfault at 58 ip 000000000805aab6 sp 00000000ff87dcc0 error 4 in manaRequest.cgi[8048000+24000]
[ 6074.680001]  in manaRequest.cgi[8048000+24000]
[ 6090.043573] manaRequest.cgi[27182]: segfault at 58 ip 000000000805aab6 sp 00000000ffab64f0 error 4 in manaRequest.cgi[8048000+24000]
[ 6090.146122] manaRequest.cgi[27185]: segfault at 58 ip 000000000805aab6 sp 00000000ff88d890 error 4 in manaRequest.cgi[8048000+24000]
[ 6105.322116] manaRequest.cgi[27361]: segfault at 58 ip 000000000805aab6 sp 00000000ffbac2c0 error 4 in manaRequest.cgi[8048000+24000]
[ 6120.484718] manaRequest.cgi[27675]: segfault at 58 ip 000000000805aab6 sp 00000000ff913fb0 error 4 in manaRequest.cgi[8048000+24000]
[ 6120.586946] manaRequest.cgi[27678]: segfault at 58 ip 000000000805aab6 sp 00000000fff40fc0 error 4 in manaRequest.cgi[8048000+24000]
[ 6136.200354] manaRequest.cgi[27986]: segfault at 58 ip 000000000805aab6 sp 00000000ff9a8a60 error 4 in manaRequest.cgi[8048000+24000]
[ 6136.302235] manaRequest.cgi[27987]: segfault at 58 ip 000000000805aab6 sp 00000000fff71b80 error 4 in manaRequest.cgi[8048000+24000]
[ 6151.480403] manaRequest.cgi[28344]: segfault at 58 ip 000000000805aab6 sp 00000000ffa94370 error 4 in manaRequest.cgi[8048000+24000]
[ 6152.480738] manaRequest.cgi[28345]: segfault at 58 ip 000000000805aab6 sp 00000000ffdf2f60 error 4 in manaRequest.cgi[8048000+24000]
[ 6166.790212] manaRequest.cgi[28598]: segfault at 58 ip 000000000805aab6 sp 00000000ff83e250 error 4 in manaRequest.cgi[8048000+24000]
[ 6166.891420] manaRequest.cgi[28600]: segfault at 58 ip 000000000805aab6 sp 00000000ffae3b50 error 4 in manaRequest.cgi[8048000+24000]
[ 6198.561690] manaRequest.cgi[30036]: segfault at 58 ip 000000000805aab6 sp 00000000ff91fef0 error 4 in manaRequest.cgi[8048000+24000]
[ 6198.661740] manaRequest.cgi[30039]: segfault at 58 ip 000000000805aab6 sp 00000000ffbecb10 error 4 in manaRequest.cgi[8048000+24000]
[ 6213.915756] manaRequest.cgi[22014]: segfault at 58 ip 000000000805aab6 sp 00000000ffc3d940 error 4 in manaRequest.cgi[8048000+24000]
[ 6229.074263] manaRequest.cgi[22211]: segfault at 58 ip 000000000805aab6 sp 00000000ff970de0 error 4 in manaRequest.cgi[8048000+24000]
[ 6244.198505] manaRequest.cgi[22443]: segfault at 58 ip 000000000805aab6 sp 00000000ffcbc7a0 error 4 in manaRequest.cgi[8048000+24000]
[ 6244.298140] manaRequest.cgi[22446]: segfault at 58 ip 000000000805aab6 sp 00000000ffd16f30 error 4 in manaRequest.cgi[8048000+24000]
[ 6259.423656] manaRequest.cgi[22594]: segfault at 58 ip 000000000805aab6 sp 00000000ffe21d50 error 4 in manaRequest.cgi[8048000+24000]
[ 6259.524584] manaRequest.cgi[22597]: segfault at 58 ip 000000000805aab6 sp 00000000ffb04ee0 error 4 in manaRequest.cgi[8048000+24000]
[ 6274.770672] manaRequest.cgi[22895]: segfault at 58 ip 000000000805aab6 sp 00000000ffbe4730 error 4 in manaRequest.cgi[8048000+24000]
[ 6274.874242] manaRequest.cgi[22898]: segfault at 58 ip 000000000805aab6 sp 00000000ff863a00 error 4 in manaRequest.cgi[8048000+24000]
[ 6290.181841] manaRequest.cgi[23109]: segfault at 58 ip 000000000805aab6 sp 00000000ffd472e0 error 4
[ 6290.189479] manaRequest.cgi[23112]: segfault at 58 ip 000000000805aab6 sp 00000000ff919c90 error 4 in manaRequest.cgi[8048000+24000]
[ 6290.202657]  in manaRequest.cgi[8048000+24000]
[ 6307.170899] manaRequest.cgi[2650]: segfault at 58 ip 000000000805aab6 sp 00000000ffdab660 error 4 in manaRequest.cgi[8048000+24000]
[ 6307.276605] manaRequest.cgi[2664]: segfault at 58 ip 000000000805aab6 sp 00000000ffa87730 error 4 in manaRequest.cgi[8048000+24000]
[ 6322.944766] manaRequest.cgi[3288]: segfault at 58 ip 000000000805aab6 sp 00000000ffc06e80 error 4 in manaRequest.cgi[8048000+24000]
[ 6323.035382] manaRequest.cgi[3285]: segfault at 58 ip 000000000805aab6 sp 00000000ffa34150 error 4 in manaRequest.cgi[8048000+24000]
[ 6338.256574] manaRequest.cgi[3824]: segfault at 58 ip 000000000805aab6 sp 00000000ff8e4200 error 4 in manaRequest.cgi[8048000+24000]
[ 6339.258141] manaRequest.cgi[3827]: segfault at 58 ip 000000000805aab6 sp 00000000ff99ce20 error 4 in manaRequest.cgi[8048000+24000]
[ 6370.469753] manaRequest.cgi[5096]: segfault at 58 ip 000000000805aab6 sp 00000000ffd06900 error 4 in manaRequest.cgi[8048000+24000]
[ 6385.588885] manaRequest.cgi[5237]: segfault at 58 ip 000000000805aab6 sp 00000000ff8ad8f0 error 4 in manaRequest.cgi[8048000+24000]
[ 6400.714259] manaRequest.cgi[5629]: segfault at 58 ip 000000000805aab6 sp 00000000ffd4a230 error 4
[ 6400.721797] manaRequest.cgi[5632]: segfault at 58 ip 000000000805aab6 sp 00000000ff843450 error 4 in manaRequest.cgi[8048000+24000]
[ 6400.734868]  in manaRequest.cgi[8048000+24000]
[ 6415.835863] manaRequest.cgi[5801]: segfault at 58 ip 000000000805aab6 sp 00000000ffcd0c00 error 4 in manaRequest.cgi[8048000+24000]
[ 6416.836731] manaRequest.cgi[5803]: segfault at 58 ip 000000000805aab6 sp 00000000ffc15e90 error 4 in manaRequest.cgi[8048000+24000]
[ 6431.967633] manaRequest.cgi[6019]: segfault at 58 ip 000000000805aab6 sp 00000000fffa3e90 error 4 in manaRequest.cgi[8048000+24000]
[ 6447.092452] manaRequest.cgi[6398]: segfault at 58 ip 000000000805aab6 sp 00000000ffc87150 error 4 in manaRequest.cgi[8048000+24000]
Wyłączyłeś wszystkie aplikacje przed sprawdzeniem tego?
Jak że by inaczej ;) Oczywiście tak. To niestety nie to. Jedyna pozytywna informacja to to, ze już wiem z czego to. Komunikaty zaczynają się pojawiać z chwilą zalogowania się do QTS. To interface webowy to generuje. Z chwila zamknięcia strony wszystko wraca do normy.
Z innej bajki w tej wersji przestał działać TVHeadend. Nie rozpoznaje już obecności tunera DVB-T. Nadmienię ze tuner ma się swietnie i TVHeadent w starej wersji z TVStation radzi sobie OK. To tylko tak na marginesie, nie walczyłem z tym jeszcze.
  1. manarequest
