Download [Public Beta] QTS 4.2.1 Build 1224 | HS-251, TS-X51, X53 (X53A), X63, X70, X71, IS-400 & TDS-16489U
Silas Mariusz
rm -rf /
Help us, GOD!
10 326
34
2 658
153
40
forum.qnap.net.pl
[Applicable Models]
HS-251, HS-251+, TS-x51, TS-x53, TS-x53A, TVS-x63, TS-x70, TVS-x70, TVS-x71, TVS-871T series, and TDS-16489U
[Bug Fixes]
This release has corrected the following issues:
- [Snapshot Replica] Replica Job keeps running in 100% stage & won't be able to finish the job.
[Download]
http://eu1.qnap.com/Storage/TVS-X71/TVS-X71_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TS-670ProTurboNAS/TS-670_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TS-X63U/TS-X63U_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TVS-X63/TVS-X63_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TS-X51U/TS-X51U_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TS-1270U-RP/TS-1270U_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/HS-251/HS-251_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TS-X53S/TS-X53S_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TS-X89U/TS-X89U_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TS-563/TS-563_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TS-870U-RP/TS-870U_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/IS-400/IS-400_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TS-X53/TS-X53_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TS-X51/TS-X51_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TS-470U-RP/TS-470U_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TVS-X71U/TVS-X71U_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TS-X53A/TS-X53A_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TS-X53U/TS-X53U_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TS-470ProTurboNAS/TS-470_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TS-870ProTurboNAS/TS-870_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TS-X80/TS-X80_20151224-4.2.1.zip
http://eu1.qnap.com/Storage/TS-X80U/TS-X80U_20151224-4.2.1.zip
Czy na tej becie ktoś z was ma problem z błędami [Kernel] Out-of-Memory i mordowaniem różnych procesów? Z góry mówię, że nie chodzi o oczywisty przypadek kiedy brakuje pamięci. Mam 16GB ramu i zajętość nie przekracza 20%. Problem z reguły pojawia się tak raz czasem dwa razy dziennie o różnych porach. Zastanawiam się czy to tak u mnie czy jeszcze ktoś to zaobserwował ? Przy poprzednich wersjach tego nie zaobserwowałem.
Przeglądałem to i nie wydaje mi się. Przy najmniej ja nie widzę jakiejś nadmiernej konsumpcji. Trudno złapać ten moment bo jest bardzo losowy. Jak sprawdzam to wszystko wygląda normalnie. Godziny w jakich się te błędy pojawiają też nie są szczególne. Obserwuje to od tej wersji bety. Nie instalowałem w zasadzie też nic nowego od finalnej wer. 4.2. Chyba tylko tvheanded i squida do potestowania, ale o ile pamiętam to zaczęło się wcześniej.
jak pisałem squid nie ma nic do tego. Było zanim go zainstalowałem.
Dziś przytrafiło mi się to samo...
11:14:37 Logman: QNAP: Event Logs:
2016-01-23 · 11:14:26 —— System×NAS —— WARN: [Kernel] Out-Of-Memory. Kill process 14576(kodi.bin). To reclaim memory resources, try disabling some applications or consider expanding the system memory (if possible).
Będę analizował sprawe.
Przez kilka dni robiłem różne testy ze wszystkimi praktycznie aplikacjami i nic z tego specjalnie nie wynikło. Wszystko powtarza się co 2-3 dni. Ubijane są różne aplikacje. Trudno jest złapać sam moment bo trwa to krótko i sporadycznie. Udało mi się przedwczoraj złapać go na gorącym uczynku i to akurat podczas niezłego nawału błędów. Sprawdziłem całkiem sporo rzeczy. Niestety wniosek jest taki, że to coś w samym systemie. Htop, top etc.. nic nie pokazują. Żadnych zmian. Na nasie nic nie jest w tym czasie robione, po prostu odpoczywa. Tylko na panelu QNAPa widać skok zajętości pamięci i wtedy ubija procesy. To jest nagłe i chwilowe. To nie jest jakiś systematyczny wyciek pamięci.
  1. reclaim
