Pomoc QNAP TS-259 PRO - rtorrent-Pro?
MM1973
29 Czerwiec 2020
100 GbE
Hello,
since I'm not sure, I prefer to ask in advance.
Can you install rtorrent-Pro on a QNAP TS-259 PRO?
Many thanks.
Best regards,
MM1973
Thank you for the feedback.
I found the following for this NAS:
CPU Intel® Atom™ Dual-core Processor
DRAM 1GB DDRII RAM
Flash Memory 512MB DOM
HDD 2 x 2.5"/3.5" SATA
NOTE:
The system is shipped without HDD.
QTS
4.2.6 build 20210327 2021-04-01
I hope it helps you?
