I have installed rTorrent++ 0.9.2 (0422), and the rTorrent part works nicely. However, my autodl-irssi keeps spitting out error messages:
And they just keep coming. Nothing that happens on IRC shows up in Irssi either, I just get a new error message everytime someone writes something in a channel for instance. I have checked that Perl module is loaded, /LOAD gives the following output:
Module Type Submodules
perl static core fe
Any ideas what could be wrong, and how it can be fixed?
Thanks in advance!
By the way, I added a <space> to the package name mentioned above to avoid getting :s smilies...21:00 -!- Irssi: ERROR: _onMessageJoin: ex: Can't locate object method "isupport" via package "Irssi::Irc:: Server" at /usr/bin/rtorrent/root/.irssi/scripts/AutodlIrssi/ChannelMonitor.pm line 134.
21:00 -!- Irssi: ERROR: Exception in onPrivmsg: Can't locate object method "isupport" via package "Irssi::Irc:: Server" at /usr/bin/rtorrent/root/.irssi/scripts/AutodlIrssi/IrcHandler.pm line 95.
perl static core fe
Thanks in advance!
