Pomoc Rtorrent pro logs
guffi
ZFS Master on QTS!
Q's Expert
13 Marzec 2020
342
Mam najnowszego rtorrent pro wgranego i chciałbym żeby ktoś sprawdził w logach czy wszystko ok
Ostrzeżenie    2023-09-07    08:27:19    rtorrent    127.0.0.1    ---    ---    ---    ---    (warn) rtorrent: Update is available: 0.9.9-0010 (current 0.9.9-0011). Download update: https://www.myqnap.org/product/rtorrent-pro/
Ostrzeżenie    2023-09-07    08:27:15    rtorrent    127.0.0.1    ---    ---    ---    ---    (warn) rtorrent: Deleting existing directory in place of target symlink: /usr/bin/rtorrent.
Ostrzeżenie    2023-09-07    08:26:02    rtorrent    127.0.0.1    ---    ---    ---    ---    (warn) rtorrent: Lock file not found. This error 2530:0.9.9-0010 should not happen....
Ostrzeżenie    2023-09-07    08:25:14    rtorrent    127.0.0.1    ---    ---    ---    ---    (warn) rtorrent: php-fpm error occured while executing stop sequence.
Ostrzeżenie    2023-09-07    08:25:14    rtorrent    127.0.0.1    ---    ---    ---    ---    (warn) rtorrent: rtorrent error occured while executing stop sequence.
Ostrzeżenie    2023-09-07    08:25:13    rtorrent    127.0.0.1    ---    ---    ---    ---    (warn) rtorrent: Unable to remove UPnP mapped ports.
Ostrzeżenie    2023-09-07    08:25:13    rtorrent    127.0.0.1    ---    ---    ---    ---    (warn) rtorrent: lighttpd error occured while executing stop sequence.
  1. Rtorrent-Pro
  2. unable to map ports
  3. upnp
  4. rtorrent
