Pomoc rTorrent-Pro not working on my TS-669L
NFaberg
16 Wrzesień 2018
TS-x69L
  • TS-x69L
  • 1 GbE
  • TS-669L fw: 4.3.4.0695 / TS-1635AX fw: 4.3.5.0699 (Public Beta 3)
@Silas Mariusz , Hi Silas, I bought yesterday RTorrent-Pro at qnapclub.eu for my TS-669L (Atom) but when I tried to install ver. 0.9.6-0912/0.9.6-0806 nothing happens. The only version i succeeded to install was rtorrent standard 0.9.6-0719.
I recently bought TS-1635AX but the installation package is incompatible.
Two the questions:
- I hoped to keep my glorious 669L to use RTorrent and satisfy the need of TB with 1635AX but now this is possible in the future? There will be new versions for X86-64 compatible with Atom processors?
- I read that you are working for a RTorrent-Pro version for ARM processors and so also for my 1635AX (I hope). It's correct? Only I have to wait for the release?
Thanks in advance.
________________________
MyQnap:
TS-669L
Firmware: 4.3.4.0695 build 20180830
TS-1635AX
Firmware: 4.3.5.0699 (Public Beta 3) build 20180914
Hi Man!
Youre correct about rTorrent-Pro for ARM. Im already working on it.
But current release should work on your Intel based unit.
Can you do me a favor and follow steps bellow?
  1. Uninstall any rTorrent build on your QNAP NAS
  2. Restart your QNAP NAS
  3. Wait several minutes after full NAS reboot to make sure all services and apps are already running.
  4. Put rtorrent_0.9.6-0912-180912_x86_64.qpkg in the root of Public share
  5. Use some SSH client like PuTTY to log into your QNAP NAS TS-669L by SSH
  6. Using console go into Public share by command:
    cd /share/Public
  7. Install rtorrent-Pro using this command:
    sh rtorrent_0.9.6-0912-180912_x86_64.qpkg
    Please paste here an output from installation process.
  8. Please also execute these commands and show me an output:
    /etc/init.d/rtorrent.sh stop
    /etc/init.d/rtorrent.sh start
Contact with me will be difficult for 2 days, but Ill try do my best to provide you support.
  • TS-x69L
  • 1 GbE
Hi Silas,
thanks for your reply.
I try the installation as you explained and i will post the result of procedure!
Thanks a lot.
MyQnap:
TS-669L
TS-1635AX
  • TS-x69L
  • 1 GbE
Hi Silas, I tried to do as explained.
It was more difficult than I though (I'm a newbie in this matters) but I followed what you clearly told me...
It Seemed that the not successful install of the downloaded package was due to an error in the qpkg. I downloaded it four times and the third file seemed to be ok and correctly installed. But it wasnt… I tried several times. %-}
At the end… i removed the package in App center and the system permitted me to install it from my payed repository from qnapclub.eu. Nas downloaded the qpkg from there and successfully installed it… :uf:
Now rtorrent events says:
19.09.2018 10:22:32] WebUI started.
[19.09.2018 10:38:09] ruTorrent cannot determine the UID of rTorrent user. Some functionality will be unavailable.
[19.09.2018 10:38:09] rTorrent is compiled with incorrect version of xmlrpc-c library, without i8 support. Version must be >= 1.11. Some functionality will be unavailable.
[19.09.2018 10:38:09] autotools: Some functionality will be unavailable. Webserver user must have execute access to the rtorrent session directory ().
[19.09.2018 10:38:09] rutracker_check: Plugin will not work. Webserver user must have execute access to the rtorrent session directory ().
What does it means?
Thanks for your support!
Here below the output from installation process.
login as: admin
admin@192.168.1.41's password:
[~] # cd /share/Public
[/share/Public] # sh rtorrent_0.9.6-0912-180912_x86_64.qpkg
Install QNAP package on TS-NAS...
./built_info
./qinstall.sh
./package_routines
./qpkg.cfg
11093+1 records in
11093+1 records out
272686689 bytes (260.1MB) copied, 6.336550 seconds, 41.0MB/s
266295+1 records in
266295+1 records out
272686689 bytes (260.1MB) copied, 6.336630 seconds, 41.0MB/s
Firmware check is fine.
[App Center] Failed to install rtorrent due to data file error.
Installation Abort.
./built_info
./qinstall.sh
./package_routines
./qpkg.cfg
11093+1 records in
11093+1 records out
272686689 bytes (260.1MB) copied, 5.684570 seconds, 45.7MB/s
266295+1 records in
272686689 bytes (260.1MB) copied, 5.686096 seconds, 45.7MB/s
rtorrent is already installed. Setup will now perform package upgrading.
Installation Abort.
[/share/Public] # sh rtorrent_0.9.6-0912-180912_x86_64ter.qpkg
./built_info
./qinstall.sh
./package_routines
./qpkg.cfg
11100+1 records in
11100+1 records out
272854804 bytes (260.2MB) copied, 5.441060 seconds, 47.8MB/s
266459+1 records in
266459+1 records out
272854804 bytes (260.2MB) copied, 5.351922 seconds, 48.6MB/s
Link service start/stop script: rtorrent.sh
Set QPKG information in /etc/config/qpkg.conf
(warn) rtorrent: Default username and password rtorrent:admin has been set for user interface. For safety, please change default login credentials.
(warn) rtorrent: There is no account set for FloodUI. For safety, please go to FloodUI and setup new login credentials.
[App Center] Installed rtorrent-Pro 0.9.6-0912 in /share/CACHEDEV1_DATA/.qpkg/rtorrent.
(info) rtorrent: Program located in PROGDIR: /share/CACHEDEV1_DATA/.qpkg/rtorrent and executed at ORIGDIR: /share/CACHEDEV1_DATA/.qpkg/.tmp
(info) rtorrent: RT_DOWNLOAD_SHARE: /share/Download
(info) rtorrent: RT_MULTIMEDIA_SHARE: /share/Multimedia
(info) rtorrent: Creating directory: /share/Download/rtorrent/settings/filebot
(info) rtorrent: Creating label dir: /share/Download/rtorrent/medialibrary
(info) rtorrent: Setting Advanced UI defaults
(info) rtorrent: Fix no more PTYs issue
(info) rtorrent: Creating link: /usr/bin/rtorrent
(info) rtorrent: exec: ln -sf /share/CACHEDEV1_DATA/.qpkg/rtorrent /usr/bin/rtorrent
(info) rtorrent: Creating link: /usr/bin/mc
(info) rtorrent: exec: ln -sf /share/CACHEDEV1_DATA/.qpkg/rtorrent/bin/mc /usr/bin/mc
(info) rtorrent: exec: ln -sf /share/Download/rtorrent/medialibrary /share/Multimedia/rtorrent
./built_info
./qinstall.sh
./package_routines
./qpkg.cfg
11093+1 records in
11093+1 records out
266295+1 records in
Installation Abort.
./built_info
./qinstall.sh
./package_routines
./qpkg.cfg
11100+1 records in
11100+1 records out
266459+1 records in
./built_info
./qinstall.sh
./package_routines
./qpkg.cfg
11093+1 records in
11093+1 records out
266295+1 records in
rtorrent is already installed. Setup will now perform package (info) rtorrent: TZ: Europe/Amsterdam
init.d/rtorrent: Force Stop engine program: rtorrent
(info) rtorrent: Port SCGI: 19000 is available.
(info) rtorrent: Port Plain-http-Web: 6009 is available.
(info) rtorrent: Port SSL-https-Web: 6008 is available.
(info) rtorrent: Port Xtra-Web-http-Monitorix: 6007 is available.
(info) rtorrent: Port DHT: 6881 is available.
(info) rtorrent: Port Torrent: 42000 is available.
(info) rtorrent: Port FloodUI: 3000 is available.
(info) rtorrent: Default network interface is: eth0 and its ipaddr is: 192.168.1.41
(info) rtorrent: Available network interfaces: eth0 eth1
(info) rtorrent: Ping success to googles host using eth0 and its ipaddr: 192.168.1.41
(info) rtorrent: Ping success to googles host using eth1 and its ipaddr: 192.168.1.6
( ) rtorrent: GeoIP db_update ------------
( ) rtorrent: Port mapping: NAT-PMP ------
(info) rtorrent: IP Geolocation db_update: Country: GeoIP.dat
( ) rtorrent: Port mapping: UPnP ---------
(info) rtorrent: UPnP Port mapping: 19000, 6881, 42000
(info) rtorrent: external ipaddr: 151.65.4.160
(info) rtorrent: Cloud host name: NASDB913E
(info) rtorrent: Cloud domain name: myqnapcloud.com
(info) rtorrent: User mail address: fabrizio.normanno@gmail.com
(info) rtorrent: IP Geolocation db_update: City: GeoIPCity.dat
(info) rtorrent: Creating the self-signed certificate.
Generating a 1024 bit RSA private key
writing new private key to '/share/CACHEDEV1_DATA/.qpkg/rtorrent/etc/lighttpd/lighttpd.pem'
(info) rtorrent: Generating new RPC password.
(info) rtorrent: PortMapper: Exits with exit status (0)
(info) rtorrent: Applying new RPC password.
(info) rtorrent: Searching application update...
(warn) rtorrent: Update is available: 2018.0911.0 (current 2018.0912.0). Download update: Zasoby
(info) rtorrent: Current ipfilter size is 3665198 bytes
(info) rtorrent: Remote ipfilter size is 290929 bytes
(info) rtorrent: Downloading new ipfilter list...
(info) rtorrent: Converting ipfilter list...
(info) rtorrent: Replacing old ipfilter list
(info) rtorrent: IP-Geolocation db_update: Exits with exit status (0)
init.d/monitorix: Starting monitorix rtorrent-monitorix
(info) rtorrent: monitorixd started.
init.d/php5-fpm: Starting service done.
(info) rtorrent: php-fpm started.
init.d/rtorrent: Starting engine program: rtorrent
(info) rtorrent: rtorrent started.
init.d/lighttpd: Starting web server rtorrent-webserver
(info) rtorrent: lighttpd started.
(info) rtorrent: Waiting for background processes to finish... (32318 32317)
(info) rtorrent: Background jobs done. (32318 32317)
(info) rtorrent: Scheduling Watchdog Services into Crontab
warn: --minUptime not set. Defaulting to: 1000ms
warn: --spinSleepTime not set. Your script will exit if it does not stay up for at least 1000ms
info: Forever processing file: server/bin/start.js
[/share/Public] #
./built_info
./qinstall.sh
./package_routines
./qpkg.cfg
11100+1 records in
11100+1 records out
272854804 bytes (260.2MB) copied, 9.997344 seconds, 26.0MB/s
266459+1 records in
272854804 bytes (260.2MB) copied, 9.997453 seconds, 26.0MB/s
rtorrent 0.9.6-0912 is already installed. Setup will now perform package upgrading.
(info) rtorrent: Removing Watchdog Services from Crontab
init.d/lighttpd: Stop lighttpd from PID: 3381
( ) rtorrent: Port removing: UPnP --------
(info) rtorrent: Removing UPnP mapped ports...
(info) rtorrent: lighttpd shutted down.
init.d/rtorrent: Stopping engine program: rtorrent
init.d/rtorrent: Socket/Lock file: /share/Download/rtorrent/session/rtorrent.lock
init.d/rtorrent: Stop rtorrent from PID: 1923
init.d/rtorrent: -SIGINT: Sending Term Interrupt signal.
init.d/rtorrent: -SIGINT ... 28 seconds left
( ) rtorrent: Port removing: NAT-PMP -----
init.d/rtorrent: -SIGINT ... 27 seconds left
init.d/rtorrent: -SIGINT ... 26 seconds left
init.d/rtorrent: -SIGINT ... 25 seconds left
init.d/rtorrent: -SIGINT ... 24 seconds left
init.d/rtorrent: -SIGINT ... 23 seconds left
init.d/rtorrent: -SIGINT ... 22 seconds left
(info) rtorrent: rtorrent shutted down.
init.d/php5-fpm: -WAIT 0
init.d/php5-fpm: Gracefully shutting down done.
(info) rtorrent: php-fpm shutted down.
init.d/monitorix: Stop monitorix from PID: 1191
(info) rtorrent: monitorixd shutted down.
info: Forever stopped process:
uid command script forever pid id logfile uptime
[0] msD_ /share/CACHEDEV1_DATA/.qpkg/rtorrent/bin/node server/bin/start.js 5581 5717 /usr/bin/rtorrent/root/.forever/msD_.log 0:0:0:39.844
(info) rtorrent: Removing link: /usr/bin/mc
(info) rtorrent: Removing link: /usr/bin/rtorrent
(info) rtorrent: Waiting for background processes to finish... (7732 )
(info) rtorrent: Background jobs done. (7732 )
[/share/Public] # [/share/Public] # sh rtorrent_0.9.6-0912-180912_x86_64.qpkg
-sh: [/share/Public]: No such file or directory
[/share/Public] # Install QNAP package on TS-NAS...
-sh: Install: command not found
[/share/Public] # ./
-sh: ./: is a directory
[/share/Public] # ./built_info
-sh: ./built_info: No such file or directory
[/share/Public] # ./qinstall.sh
-sh: ./qinstall.sh: No such file or directory
[/share/Public] # ./package_routines
-sh: ./package_routines: No such file or directory
[/share/Public] # ./qpkg.cfg
g
-sh: ./qpkg.cfg: No such file or directory
[/share/Public] # 11093+1 records in
-sh: 11093+1: command not found
[/share/Public] # 11093+1 records out
< bytes (260.1MB) copied, 5.684570 seconds, 45.7MB/s
-sh: syntax error near unexpected token `('
[/share/Public] # 266295+1 records in
-sh: 266295+1: command not found
[/share/Public] # 266295+1 records out
< bytes (260.1MB) copied, 5.686096 seconds, 45.7MB/s
< is already installed. Setup will now perform package upgrading.
-sh: rtorrent: command not found
[/share/Public] # Firmware check is fine.
-sh: Firmware: command not found
<er] Failed to install rtorrent due to data file error.
-sh: [App: command not found
[/share/Public] # Installation Abort.
-sh: Installation: command not found
<ublic] # sh rtorrent_0.9.6-0912-180912_x86_64ter.qpkg
o
[/share/Public] # 11100+1 records in
-sh: 11100+1: command not found
[/share/Public] # 11100+1 records out
< bytes (260.2MB) copied, 5.441060 seconds, 47.8MB/s
[/share/Public] # 266459+1 records in
-sh: 266459+1: command not found
[/share/Public] # 266459+1 records out
< bytes (260.2MB) copied, 5.351922 seconds, 48.6MB/s
[/share/Public] #
./built_info
./qinstall.sh
./package_routines
./qpkg.cfg
11100+1 records in
11100+1 records out
272854804 bytes (260.2MB) copied, 6.788619 seconds, 38.3MB/s
266459+1 records in
272854804 bytes (260.2MB) copied, 6.791343 seconds, 38.3MB/s
(info) rtorrent: Lock file not found. Stop aborted.
[/share/Public] # Link service start/stop script: rtorrent.sh
-sh: Link: command not found
[/share/Public] # Set QPKG information in /etc/config/qpkg.conf
-sh: Set: command not found
<erface. For safety, please change default login credentials.
-sh: syntax error near unexpected token `rtorrent:'
<ety, please go to FloodUI and setup new login credentials.
< 0.9.6-0912 in /share/CACHEDEV1_DATA/.qpkg/rtorrent.
<xecuted at ORIGDIR: /share/CACHEDEV1_DATA/.qpkg/.tmp
[/share/Public] # (info) rtorrent: RT_DOWNLOAD_SHARE: /share/Download
[/share/Public] # (info) rtorrent: RT_MULTIMEDIA_SHARE: /share/Multimedia
<orrent: Creating directory: /share/Download/rtorrent/settings/filebot
<orrent: Creating label dir: /share/Download/rtorrent/medialibrary
[/share/Public] # (info) rtorrent: Setting Advanced UI defaults
[/share/Public] # (info) rtorrent: Fix no more PTYs issue
[/share/Public] # (info) rtorrent: Creating link: /usr/bin/rtorrent
<orrent: exec: ln -sf /share/CACHEDEV1_DATA/.qpkg/rtorrent /usr/bin/rtorrent
[/share/Public] # (info) rtorrent: Creating link: /usr/bin/mc
<orrent: exec: ln -sf /share/CACHEDEV1_DATA/.qpkg/rtorrent/bin/mc /usr/bin/mc
<e/Download/rtorrent/medialibrary /share/Multimedia/rtorrent
[/share/Public] #
[/share/Public] # [App Center
[/share/Public] #
./built_info
./qinstall.sh
./package_routines
./qpkg.cfg
11100+1 records in
11100+1 records out
272854804 bytes (260.2MB) copied, 12.942573 seconds, 20.1MB/s
266459+1 records in
272854804 bytes (260.2MB) copied, 12.943201 seconds, 20.1MB/s
<orrent: Default username and password rtorrent:admin
[/share/Public] # (warn) rtorrent: There is no acco
-sh: [A: command not found
-sh: syntax error near unexpected token `rtorr'
-sh: syntax error near unexpected token `rtorre'
-sh: syntax error near unexpected token `rto'
[/share/Public] # (info) rtorrent: ex
<orrent: exec: ln -sf /share/Download/rtorrent/medialibrary /shar
[/share/Public] #
[/share/Public] # ///etc/init.d/rtorrent.sh stop
(info) rtorrent: Program located in PROGDIR: /share/CACHEDEV1_DATA/.qpkg/rtorrent and executed at ORIGDIR: /share/Public
[/share/Public] # /etc/init.d/rtorrent.sh start
(err!) rtorrent: application launch is disabled. Enable it first!
[/share/Public] #
  • TS-x69L
  • 1 GbE
Hi Silas, i'm back.
I found my rtorrent not responding at all…
Tried via putty/admin commands:
  1. /etc/init.d/rtorrent.sh stop
  2. /etc/init.d/rtorrent.sh start
here the log:
[~] # /etc/init.d/rtorrent.sh stop
(info) rtorrent: Program located in PROGDIR: /share/CACHEDEV1_DATA/.qpkg/rtorrent and executed at ORIGDIR: /root
init.d/lighttpd: PID file not found: /var/run/rtorrent-webserver.pid
(warn) rtorrent: lighttpd error occured while executing stop sequence.
init.d/rtorrent: Socket/Lock file: /share/Download/rtorrent/session/rtorrent.lock NOT FOUND
(warn) rtorrent: rtorrent error occured while executing stop sequence.
init.d/php5-fpm: Gracefully shutting down warning, no pidfile found - ..is not running ?
(warn) rtorrent: php-fpm error occured while executing stop sequence.
init.d/monitorix: PID file not found: /var/run/rtorrent-monitorix.pid
(warn) rtorrent: monitorixd error occured while executing stop sequence.
error: Forever cannot find process with id: server/bin/start.js
(info) rtorrent: Waiting for background processes to finish... (31688 )
(info) rtorrent: Background jobs done. (31688 )
[~] # /etc/init.d/rtorrent.sh start
(info) rtorrent: external ipaddr: 151.65.29.194
(info) rtorrent: Web server certificate found.
(info) rtorrent: Current ipfilter size is 290941 bytes
(info) rtorrent: Remote ipfilter size is 290979 bytes
(info) rtorrent: Waiting for background processes to finish... (4118 4117)
(info) rtorrent: Background jobs done. (4118 4117)
I found your rev 924! Ill try to update…
What do you mean with "prepare TeamViewer and putty"?
i've not found TeamViewer app for qnap…
update:
i'm not able to update to 924...
The only way i think is to download the update and re-install, as the was no rtorrent already installed.
I'm doing so
What it means?
15 minutes from beginning of installation but has not yet completed, it is at 75%...
  • TS-x69L
  • 1 GbE
Hi Silas, i've installed from shell
_________________________________________________________
[/share/Public] # sh rtorrent_0.9.6-0924-180924_x86_64.qpkg
./built_info
./qinstall.sh
./package_routines
./qpkg.cfg
11131+1 records in
11131+1 records out
273610774 bytes (260.9MB) copied, 6.006554 seconds, 43.4MB/s
267198+0 records in
267198+0 records out
273610752 bytes (260.9MB) copied, 6.007573 seconds, 43.4MB/s
rtorrent 0.9.6-0924 is already installed. Setup will now perform package upgrading.
[App Center] Installed rtorrent-Pro 0.9.6-0924 in /share/CACHEDEV1_DATA/.qpkg/rtorrent.
___________________________________________________________
I found rtorrent again non responding.
Often i find in nas log: rtorrent 127.0.0.1 localhost (warn) rtorrent: watchdog svc: rtorrent is down. Relaunching…
(info) rtorrent: Default network interface is: eth0 and its ipaddr is: 192xxxxxxxxxxxx
(info) rtorrent: Ping success to googles host using eth0 and its ipaddr: 192xxxxxxxxxxxxxxxxxx
(info) rtorrent: Ping success to googles host using eth1 and its ipaddr: 192xxxxxxxxxxxxxxx
(info) rtorrent: external ipaddr: xxxxxxxxxxxxxxxxxxxxx
(info) rtorrent: Cloud host name: xxxxxxxxxxxxxxxxxxx
(info) rtorrent: User mail address: xxxxxxxxxxxxxxxxxxxxxxxxxxxx
(warn) rtorrent: Update is available: 2018.0911.0 (current 2018.0924.0). Download update: Zasoby
(info) rtorrent: Current ipfilter size is 290979 bytes
(info) rtorrent: Remote ipfilter size is 291093 bytes
(info) rtorrent: Waiting for background processes to finish... (29990 29989)
(info) rtorrent: Background jobs done. (29990 29989)
  1. rtorrent service unavailable
