Pomoc rTorrent Pro with VPN: IP leak when connection is lost
jomsen
4 Marzec 2019
11
TS-419P
Hello All,
as soon as the ethernet connection is disconnected, for example when the router upgrades and reboots, rTorrent always leaks the non-vpn ip of the internet connection .Even if the VPN network is configured as the default gateway. My guess is that this happens until the VPN is reconnected. Is there any way to stop this leak?
Thank you!
jomsem
Firmware version: 5.0.0.1870 Build 20211201
Model name: QNAP TS-453Be
rTorrent: 0.9.8/0.13.8
Additional important Info: The VPN can not ipv6 on Qnap. But Rtorrent Pro does. This means that this will also be leaked immediately.
  1. rtorrent no default gateway
