Pomoc Not working with QTS5.0? (Relaunching... every minute)
spyuchan
16 Październik 2021
10 GbE
Model: TS-1677X
Current firmware version: QTS 5.0.0.1808 Build 20211001
rTorrent-Pro version: 0.9.8-B800
rTorrent-Pro 0.9.8-B800 was working perfectly with QTS 4.5.4.1800 build 20210923,
but not working with QTS 5.0.0.1808 Build 20211001.
Is there any way to use rTorrent-Pro with QTS5.0?
Here are what I did to solve the problem:
1. Uninstall, remove rtorrent directory and clean-install rTorrent-Pro 0.9.8-B800 -> not worked.
2. Disabled ip-filter -> not worked.
3. Installed flood-ui -> Installed successfully but flood-ui does not start. (fig. 3)
(fig. 1) Errors on notification center
(fig. 2) A capture of GUI
(fig. 3)
