D
Deleted member dav1d9
Guest
Hi, I updated to version 4.2.1 build 0419 and utorrent has stopped working properly, I can go down to the previous firmware version 4.2.0 build 20160311, thank you very much
Hello,
there is a new version that was uploaded today 2016-b0422-0.9.6
I could get past the new welcome screen with the 2 birds tho.
cheers
Hi, I tried the new version and does not work in 4.2.1, in the end I returned to previous firmware, and I have the 0.9.2 running again, back at the moment not update, I stay in 4.2.0, Greetings
Thank you for the info. Maybe i will wait a bit for a new version before i downgrade the firmware. What error message did you get?
regards
I doubt that QNAP will fix their firmware just because of rTorrent. Hopefully there is a workaround of this issue.
Hello, you tried transmission ?, I have been told that if it works with version 4.2.1, Greetings
has this problem been already reported to staff?
