Witam wszystkich,
Mam problem z podpięciem dysku poprzez przejściówkę SATA-USB. Kiedyś mi to działało, teraz nie. Ale do rzeczy.
Wymieniłem dysk na większy, wymontowany dysk chcę podpiąć przez USB i przegrać dane.
Dysk jest rozpoznawany w urz. zewn., jednak jako odmontowany - nierozpoznany system plików.
Dysk posiada system plików EXT4 - tak pracował do tej pory.
Wynik dmesg:
[41709.660337] usb 2-1: new high-speed USB device number 2 using etxhci_hcd_140522
[41709.700235] scsi3 : usb-storage 2-1:1.0
[41710.712076] scsi 3:0:0:0: Direct-Access WDC WD10 EURX-73C57Y0 PQ: 0 ANSI: 2 CCS
[41710.753131] sd 3:0:0:0: [sdq] 244190646 4096-byte logical blocks: (1.00 TB/931 GiB)
[41710.782598] sd 3:0:0:0: Attached scsi generic sg16 type 0
[41710.811085] sd 3:0:0:0: [sdq] Write Protect is off
[41710.815899] sd 3:0:0:0: [sdq] Mode Sense: 28 00 00 00
[41710.840575] sd 3:0:0:0: [sdq] No Caching mode page present
[41710.846087] sd 3:0:0:0: [sdq] Assuming drive cache: write through
[41710.885134] sd 3:0:0:0: [sdq] 244190646 4096-byte logical blocks: (1.00 TB/931 GiB)
[41710.913098] sd 3:0:0:0: [sdq] No Caching mode page present
[41710.918610] sd 3:0:0:0: [sdq] Assuming drive cache: write through
[41710.953385] sdq: sdq1 sdq2 sdq3 sdq4
[41710.957191] sdq: p3 size 15603099088 extends beyond EOD, enabling native capacity
[41711.000488] sd 3:0:0:0: [sdq] 244190646 4096-byte logical blocks: (1.00 TB/931 GiB)
[41711.030880] sd 3:0:0:0: [sdq] No Caching mode page present
[41711.036392] sd 3:0:0:0: [sdq] Assuming drive cache: write through
[41711.071565] sdq: sdq1 sdq2 sdq3 sdq4
[41711.075357] sdq: p3 size 15603099088 extends beyond EOD, truncated
[41711.081638] sdq: p4 start 15620063808 is beyond EOD, truncated
[41711.141424] sd 3:0:0:0: [sdq] 244190646 4096-byte logical blocks: (1.00 TB/931 GiB)
[41711.177483] sd 3:0:0:0: [sdq] No Caching mode page present
[41711.183021] sd 3:0:0:0: [sdq] Assuming drive cache: write through
[41711.189141] sd 3:0:0:0: [sdq] Attached SCSI disk
[41711.193782] [#] set usb polling mode (sdq)
[41711.640489] FAT-fs (sdq): invalid media value (0x00)
[41711.645474] FAT-fs (sdq): Can't find a valid FAT filesystem
[41711.893006] FAT-fs (sdq): invalid media value (0x00)
[41711.898046] FAT-fs (sdq): Can't find a valid FAT filesystem
[41712.143328] FAT-fs (sdq): invalid media value (0x00)
[41712.148314] FAT-fs (sdq): Can't find a valid FAT filesystem
[41712.393537] FAT-fs (sdq): invalid media value (0x00)
[41712.398525] FAT-fs (sdq): Can't find a valid FAT filesystem
Z góry dziękuję za pomoc.
Wersja oprogramowania Firmware: 4.2.3 Build 2017/01/21
Model serwera: QNAP TS-119P II
Wynik dmesg:
