Hello,
I'm a new rTorrent user. And I'm having some issues I hope someone can help me with. It's an old NAS so I don't expect any miracles.. And it's not 100% sure it's an rTorrent problem. But I can provide logs if you tell me which ones.
Model Name: TS-269 Pro
Firmware: 4.34.1190 Build 20200107
rTorrent version: 0.9.7-A229 29.Feb
VPN: OpenVPN client with QVPN service, and mapped tunnel to rTorrent in settings
Symptoms:
Random reboots multiple times per day. It seems to happen more frequently when I'm adding new torrents and downloading. When it's idle/seeding, it still happens, but less frequently (daily). When rTorrent qpkg is stopped, it's stable.
After the reboot the QNAP log tells me that the system did not shut down properly, prompting to do checkdisk, and the "Up-time timer" resets. Also sometimes rtorrent and plex doesn't start properly (need an additional reboot, which is fine, after a sudden reboot).
I suspected high cpu load, since the CPU does peak quite high when adding torrents. I also use plex sometimes, and if the plexplayer triggers the transcoder, it will load the cpu 100%, and I did not experience reboots with plex loading the CPU by itself. But I've had reboots while asleep and not using any of the services as well.
I also suspected a bad powersupply (even ordered a new one), but since the problem just disappeared after disabling rTorrent qpkg, I think the problem might be somewhere else.
Symptoms:
