Silas Mariusz
rm -rf /
Help us, GOD!
10 550
2 669
405
forum.qnap.net.pl
Symptoms
  • You want finished films and series to go into a tidy library, and you do not have FileBot.
  • You are wondering whether to buy a FileBot licence.
Cause
You do not need it. Movie Agent, built into the package, files the library. It identifies titles, names the folders and files, and saves the poster, the backdrop and the .nfo file after filing. Your own TMDB and TheTVDB keys are optional. FileBot is a separate program with a paid licence. When FileBot files, Movie Agent still identifies each release first and picks its branch, then files what FileBot did not place.
Resolution
  1. Open Media library in the menu. While the library is off, the page shows The library is off. Switch it on in ….
  2. In the library settings, under the Organisers card, turn on Organise finished downloads into a media library. Press Review & save and confirm the changes in the window that opens.
  3. In the Organisers card, check that the Organises the finished downloads switch on the Movie Agent tile is on. It is on after the install, and the line under it reads on: Movie Agent names, files and fetches the artwork.
Notice & Advise
  • Only one of them files. With a licence, turning on the switch on the FileBot tile turns off the one on the Movie Agent tile. Without a licence FileBot files nothing, and the tile reads off: FileBot has no licence, so Movie Agent does the filing.
  • The FileBot guide shows how to install FileBot and activate its licence.
Ref. links:
Rtorrent 16 guide: Media library
Rtorrent 16 guide: FileBot
