- 5 Kwiecień 2008
- 10 548
- 2 669
- 405
- Odznaki
- 205
- QNAP
- TS-x77
- Ethernet
- 1 GbE
Symptoms
Cause
Yes. With IPv6 set to Auto (allow IPv6), the default, rtorrent uses IPv4 and IPv6 at once. It listens on one port for both, and DHT keeps an IPv6 table on its own UDP port too. The package announces the NAS's stable global IPv6 address to trackers, never a temporary (privacy) address. IPv6 has no NAT and needs no port forwarding, but most routers drop incoming IPv6 connections until their IPv6 firewall allows them.
Resolution
Notice & Advise
Ref. links:
Rtorrent 16 guide: Ports
- Your internet connection has IPv6, and you want peers to reach the NAS over it.
- You want to know whether Rtorrent 16 uses IPv6 at all.
Cause
Resolution
- Open Network & NAT and find the IPv6 block of the BitTorrent port card. Address shows the NAS's global IPv6 address. No global IPv6 address on this NAS., or a unique-local address starting with
fd, means the internet cannot reach the NAS over IPv6.
- Check Announced to trackers: the address trackers give to IPv6 peers. Leave Announce this IPv6 to trackers in Settings → Connection empty unless trackers must get another address.
- Read Internet over. When the IPv6 setting does not fit what the check found, the button Set IPv6 mode to … and restart rtorrent appears under it. It saves the fitting setting and restarts rtorrent; nothing changes until you press it.
- In the router's IPv6 firewall, and in QuFirewall if it is on, allow incoming TCP and UDP on the BitTorrent port and UDP on the DHT port (6891 by default) to the NAS's IPv6 address.
- Press Check TCP port. The IPv6 block then reads open, not reachable or unverified.
Notice & Advise
- With Off (block IPv6 entirely), or with Bind to interface / IP set to an IPv4 address or an interface without IPv6 (most VPN tunnels), rtorrent uses IPv4 only.
- The Ports strip on Quick access shows one dot for IPv4 and one for IPv6.
Ref. links:
