- 5 Kwiecień 2008
- 10 550
- 2 669
- 405
- Odznaki
- 205
- QNAP
- TS-x77
- Ethernet
- 1 GbE
Symptoms
Cause
Rtorrent 16 runs on the NAS all the time, so the panel does not have to be open. The simplest way is the watch folder: Rtorrent 16 adds and starts every .torrent file copied into it by itself. The Rtorrent 16 app for Android also takes torrents, and so does a browser extension once the Gopeed add-on is installed.
Resolution
Notice & Advise
Ref. links:
Rtorrent 16 guide: Torrents
Rtorrent 16 guide: Phone app
- You do not want to sign in to the panel every time you add a torrent.
- You want to add torrents from your phone or straight from the browser.
Cause
Resolution
- Find the watch folder: on the Diagnostics page, the Watch folders card shows its path. By default it is
watch/in the base folder: in theRdownload16share, or inDownload/rtorrent16orPublic/rtorrent16when there is no such share.
- Copy a .torrent file into that folder, for example over the network share or with File Station. A file in a subfolder such as
watch/tv/gets the categorytv, and a file inwatch/load/is added stopped. A subfolder you make yourself starts working within five minutes. An added file leaves the folder. If a file stays, the Watch folders card lists it under Not added with the reason. - On an Android phone, install the app from the Phone app page and pair it with the NAS. Then share a .torrent file or a magnet link to the Rtorrent 16 app from another app. While the app is closed, the NAS adds the torrent at once with the category it guesses from the name, and the phone shows what was added.
- When the Gopeed add-on is installed on the NAS, the Add torrent page has a Browser integration card. Install the Gopeed extension for Chrome, Edge or Firefox from there, and enter the Server address and the Token from that card in the extension's settings. The extension sends torrents and magnet links to Rtorrent 16.
Notice & Advise
- While the panel is open, paste a magnet link or a .torrent file with Ctrl+V on any page, or drop it on the page. A window titled Add from clipboard or Add torrents opens: check the queue and press Add.
- A WhatsApp bot paired on the Notifications page and the bot of the Rtorrent 16 Telegram add-on also take a .torrent file or a magnet link sent in the chat.
Ref. links:
