Silas Mariusz
rm -rf /
Help us, GOD!
10 550
2 669
405
forum.qnap.net.pl
Symptoms
  • You want Radarr and Sonarr to add torrents to Rtorrent 16.
  • The download client test in Radarr or Sonarr fails.
Cause
Radarr and Sonarr see Rtorrent 16 as an rTorrent download client and connect to the panel's /RPC2 address. They sign in with a panel account, as you do when you sign in to the panel. The Connect another app card under Settings → Media servers shows the values to type in. The category you set in Radarr and Sonarr becomes the torrent's label.
Resolution
  1. Give the apps an account of their own. On the Security page, in the Accounts card, type a name such as arr and a password, then press Create account.
  2. Open Settings → Media servers and scroll to the Connect another app card.
  3. In Radarr, open Settings → Download Clients, press the + tile and pick rTorrent.
  4. Copy Host and Port from the card. In URL Path type RPC2, without a leading slash. In Username and Password type the name and password of the account from step 1. Tick Use SSL only when the card shows yes for Use SSL.
  5. In Category type radarr, then press Test and Save.
  6. Do the same in Sonarr, with the category sonarr.
Notice & Advise
  • The Connect another app card shows the address you opened Rtorrent 16 with in the browser, and the panel's own port. Opened over http, that is the HTTP port (6019 by default) and Use SSL: no. Opened over https, it is the HTTPS port (6018 by default) and yes. The How-to uses the HTTP port.
  • Keep the Let apps on other machines use /RPC2 (with login) switch under Settings → Web access on. It is on after the install. When you turn it off, /RPC2 answers only connections the NAS makes to itself.
  • In the media library the label radarr means a film and sonarr a series. The How-to covers the rest: a download folder for each label, Prowlarr, and turning off automatic import when Movie Agent files the downloads.
Ref. links:
How-to: Radarr, Sonarr, Prowlarr and Seerr with Rtorrent 16
