- 5 Kwiecień 2008
- 10 762
- 2 733
- 405
- Odznaki
- 205
- QNAP
- TS-x77
- Ethernet
- 1 GbE
If you use qBittorrent, try Rtorrent 16. Nothing in qBittorrent changes, your files stay where they are, and one click brings the list over and seeds it at once: 1-click import & seed now.
Rtorrent 16 reads qBittorrent’s torrent list from its App Center package. A torrent that qBittorrent finished, and whose files have not changed since, seeds in Rtorrent 16 at once without reading the data again. In our example, two torrents with 4.2 GB of data came over without a check and seeded as soon as they were added.
Before you start
- qBittorrent is installed as an App Center package, for example QBittorrent NG from myQNAP.org. Rtorrent 16 does not find a copy in Container Station.
- Rtorrent 16 is installed from the NASutils App Center repository and up to date.
- qBittorrent is stopped. In App Center open qBittorrent and press Stop. While it runs, the import window says so and waits.
Import the torrents
- Open Rtorrent 16. On a new installation the first screen of the welcome guide offers the import: press Import from qBittorrent. Later you find the same button on the Diagnostics page, on the Backups card.
- Read the window. It shows where qBittorrent keeps its list, how many torrents can come over and how many need no check. To save new downloads in the folder qBittorrent used, tick Save new downloads in qBittorrent’s folder. Press Import.
- Rtorrent 16 saves a copy of its own torrent list first, then adds the torrents. You can close the window: the import goes on.
- Read the result: how many came over, how many without a check, and how many seed. Press Done.
- Open Quick access. The imported torrents seed with the label
seed.
Keep qBittorrent stopped afterwards. If both programs run, they seed the same files twice.
Which torrents need no check
A torrent comes over without a check when qBittorrent’s own record shows every piece, and every file has its full size and has not changed since qBittorrent finished the torrent. Rtorrent 16 checks the others first: it reads their files once and sends nothing until the check ends. These torrents get the check:
- a torrent stopped in qBittorrent; it stays stopped after the check;
- a torrent added in qBittorrent with Skip hash check;
- a torrent with a file you did not want to download;
- a torrent with a file that changed after qBittorrent finished it.
A torrent with a missing file comes over stopped and downloads nothing until you start it. The result also lists what stayed out, for example a renamed file or a magnet link without metadata. The log names each one.
Questions
Do I lose my ratio?
No. The tracker counts your upload from what each client reports, so your ratio there stays. Rtorrent 16’s own upload counter starts at zero for each imported torrent.
Does it check everything again?
No. Only the torrents in the list above get a check. A finished torrent whose files nobody changed seeds at once.
Will my downloads land in the Media library?
No. Every imported torrent gets the label
seed. Rtorrent 16 then leaves it alone: no copy in the completed folder, no Media library, no Movie Agent or Game Agent, no notifications. To file one by hand, open its folder in Files and choose Re-identify (Movie Agent) in the folder’s menu. The files stay where they are.Can I go back to qBittorrent?
Yes. The import changes nothing in qBittorrent, so its list is as you left it. Stop the imported torrents in Rtorrent 16, then start qBittorrent in App Center. If you ticked the folder box, Rtorrent 16 keeps using that folder until you change Download directory in its Settings.
What does not come over?
qBittorrent’s settings, speed limits and schedules. Only the torrent list comes over, with each torrent’s folder, its trackers and the date it was added.
What does it cost?
Nothing. Rtorrent 16 and every other app on nasutils.net are freeware.
The guide with every picture: Migrate to Rtorrent 16: switch from qBittorrent and seed right away! · Rtorrent 16
