QTS 4.4.1.0948 Build 20190527 for TS-X51/TS-X53
[Important Notes]
- For the status of QTS updates and maintenance for your NAS model, visit Product Support Status :: QNAP
- This QTS update changes the file system of the system partition to ext4 for ARM-based models with Annapurna Labs processors. For data security reasons, you are not able to downgrade QTS to a previous version after this update.
Affected models: TS-131P, TS-231P, TS-431P, TS-531P, TS-231+, TS-431+, TS-231P2, TS-431P2, TS-431X, TS-431X2, TS-531X, TS-831X, TS-1231XU-RP, TS-1231XU, TS-831XU-RP, TS-831XU, TS-431XU-RP, TS-431XU, TS-431XeU, and TS-1635.
- We have fixed the vulnerabilities in the following apps to ensure your data security: Surveillance Station, QVPN Service, Qfiling, Qsync Central, QcalAgent, and IFTTT Agent. To continue using these apps, go to the App Center and update them to the latest version.
- For more information on the kernel versions for NAS models that QTS 4.4.1 supports, see QNAP Systems, Inc. - Network Attached Storage (NAS)
- Removed the following applications from App Center due to PHP 7 updates in QTS 4.4.1: "phpEasyProject", "Dolphin", "CMS Made Simple", "Vtiger CRM", "iStat", and "PostgreSQL".
- QcalAgent and Notes Station 2 are currently not supported on QTS 4.4.1 but will be available soon.
[New feature]
Control Panel - Multimedia Console
- Replaced Multimedia Management with Multimedia Console.
- Added support for sorting and hiding categories.
- Added feature that automatically uses image files as thumbnails for videos with the same filename.
- Added volume control function.
- Added support for new movie and TV show categories.
Virtualization Station
- vQTS 4.4.1 supports local installation via HTML5 console.
Control Panel - Hardware
- vQTS 4.4.1 supports GPU pass-through from Virtualization Station. This makes the resources of the assigned GPU available for use by the apps/services of that vQTS.
Encyption
- Added support for managing shared folder encryption in File Station.
File Station
- Added support for document collaboration via Microsoft Office Online.
Qtier
- Added support for removing the ultra-high speed (SSD) tier from a Qtier auto-tiering storage pool.
Snapshot
- Added Smart Snapshot Retention feature. Snapshots can now be retained by time period (hourly, daily, weekly, monthly).
Storage Management
- Added support for creating hardware-encrypted storage pools using SED drives.
- Added support for creating CacheMount cache space.
- Added support for creating a one-time scheduled file system check.
- Storage & Snapshots now tracks and displays the estimated remaining life of SSDs.
- Added support for Fibre Channel storage protocol.
- QNAP drive adapters QDA-A2AR and QDA-A2MAR can now be used to create NAS storage space.
- QNAP drive adapter QDA-UMP can now be used to create NAS storage space.
User Group
- Added quota support for user groups.
Encyption
- File Station supports encryption and decryption for files with the ".qenc" extension.
Expansion Card
- Added support for Mustang-F100 FPGA and Mustang-V100 VPU cards. You can go to Control Panel and assign them as resources for the OpenVINO™ Workflow Consolidation Tool.
App Center
- Added support for validating digital signatures and certificates.
CacheMount
- Files on mounted Google Drive accounts (.gdoc, .gslides, .gsheet) can now be downloaded as Microsoft Office files (.docx, .pptx, .xlsx) in File Station.
Network and Virtual Switch
- Added support for displaying Fibre Channel adapter information and status.
Resource monitor
- Added support for displaying kernel processes on the system processs category.
File Sharing Protocol
- Added support for Samba 4.7.
[Enhancement]
CacheMount
- The new CacheMount application has replaced remote mount in File Station. Install CacheMount from the App Center to keep using remote mount services.
Control Panel - Daylight SavingTime
- Added support for cross-year daylight saving time settings.
- Moved Media Streaming Add-on to App Center repository.
QTS - Security
- Added version settings for TLS.
- Added support for HTTP compression.
UPS
- Added support for up to 20 UPS devices.
Web Server
WebDAV
- WebDAV is now disabled by default.
Storage Management
- Updated IronWolf Health Management (IHM) to support new Seagate IronWolf and IronWolf Pro drive models.
- QTS can now check for firmware updates for connected expansion devices and then prompt you to update them each time you log in.
- Added indicators for interfaces that support WoL.
File Station
- Added support for checking access logs in file or folder properties in File Station.
Performance
- Reduced and optimized the maximum latency for SSD storage space.
[Other Changes]
Library
- Updated to SQLite 3.26.0.
- Updated the Apache version to 2.4.39.
- Updated the PHP version to 7.3.4.
File Station
- Removed the "Show files and folders of my PC" function from File Station.
[Download]
https://download.qnap.com/Storage/TS-X51/TS-X51_20190527-4.4.1.0948.zip
https://download.qnap.com/Storage/TS-X53/TS-X53_20190527-4.4.1.0948.zip
[Important Notes]
[New feature]
Encyption
File Station
Qtier
Snapshot
Storage Management
User Group
Encyption
Expansion Card
App Center
CacheMount
Resource monitor
[Enhancement]
CacheMount
QTS - Security
UPS
Web Server
WebDAV
Storage Management
File Station
Performance
[Other Changes]
Library
File Station
[Download]
